#2592: r.mapcalc: add -l flag
Reporter: martinl | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.3
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.mapcalc
Description changed by neteler:
Old description:
Add new flag to list inputs and outputs:
r.mapcalc -l "test1 = test2 + test3 + 5"
input=test2,test3
output=test1
}}}From #2409:
Such an option would be fairly simple to add. Most of the relevant logic
is already present in execute() in r.mapcalc/evaluate.c.The initialize() function populates the list of input maps (in
r.mapcalc/map.c or map3.c), which can be used to generate the list of
inputs. Each top-level assignment expression defines an output.
New description:
input=test2,test3
output=test1
From #2409:
Ticket URL: <https://trac.osgeo.org/grass/ticket/2592#comment:4>
