[GRASS-dev] [GRASS GIS] #2598: g.extension compilation fails
  Reporter: ewcgrass | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.3
Component: Default | Version: svn-releasebranch70
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Comment (by neteler):
Replying to [comment:7 ewcgrass]:
> The modules that still refuse to compile appear to be doing so because
of some issues related to file permissions (??) and/or missing header
files. For example, I have not been able to find geos_c.h anywhere within
the /grass7.0.1svn-x86_64-unknown-linux-gnu-21_02_2015 directory, which is
needed to compile r.stream.order, r.stream.snap, v.surf.mass,
v.centerpoint, etc. Also, some errors appear to maybe be related to syntax
errors; for example for modules v.transects and r.stream.basins.
The file "geos_c.h" is provided by the "geos-devel" package which must be
installed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2598#comment:12&gt;
