#2608: Launching Python script on Windows fails with missing freeze_support
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Python | Version: 7.0.0
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
Launch the following script on Windows:
from grass.pygrass.modules.shortcuts import raster as r
r.mapcalc("rand0 = round(rand(0,1))", s=True)
r.neighbors(input="rand0", output="count", method="count")
r.mapcalc("rand1 = if (count > 3, 1, null())")
r.mapcalc("rand2 = if (count < 1, 1, null())")
and observe an error:
C:\Users\tests\Documents\rand.py
File "<string>", line 1, in <module>
File "C:\Program Files\GRASS GIS
7.0.0\Python27\lib\multiprocessing\forking.py", line 380, in
main
prepare(preparation_data)
7.0.0\Python27\lib\multiprocessing\forking.py", line 495, in
prepare
'__parents_main__', file, path_name, etc
File "C:\Users\tests\Documents\rand.py", line 2, in
<module>
7.0.0\etc\python\grass\pygrass\modules\interface\module.py",
line 616, in __call__
return self.run()
line 714, in run
get_msgr().debug(1, self.get_bash())
7.0.0\etc\python\grass\pygrass\messages\__init__.py", line
352, in get_msgr
_instance[0] = Messenger(*args, **kwargs)
175, in __init__
self.start_server()
185, in start_server
self.server.start()
7.0.0\Python27\lib\multiprocessing\process.py", line 130, in
start
self._popen = Popen(self)
7.0.0\Python27\lib\multiprocessing\forking.py", line 258, in
__init__
cmd = get_command_line() + [rhandle]
7.0.0\Python27\lib\multiprocessing\forking.py", line 358, in
get_command_line
is not going to be frozen to produce a Windows executable.''')
RuntimeError:
Attempt to start a new process before the current process
has finished its bootstrapping phase.
This probably means that you are on Windows and you have
forgotten to use the proper idiom in the main module:
if __name__ == '__main__':
freeze_support()
The "freeze_support()" line can be omitted if the program
Ticket URL: <http://trac.osgeo.org/grass/ticket/2608>
