#2618: v.vector option=transfer does not copy multiple cat values
Reporter: ulf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: 7.0.0
Keywords: v.category transfer | Platform: Linux
Cpu: x86-64 |
v.vector with option=transfer only copies one category value when a
feature has multiple category values in the same layer. An example to
explain what I mean:
Cpu: x86-64 |
Comment(by ulf):
One row disappeared from my example - to create map {{{test2}}} i did the
following:
echo "100|100|1" | v.in.ascii output=test input=-
fid=$(v.edit --quiet layer=1 map=test tool=select cat=1)
v.edit map=test layer=1 tool=catadd ids=${fid} cats=2
v.category option=transfer layer=1,2 input=test output=test2
Sorry about that,
Ulf
#2618: v.category option=transfer does not copy multiple cat values
Resolution: | Keywords: v.category transfer
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
I added the commands as a Bash test case in r65485 but I actually don't
understand what the output means here (why it is the same for `layer=1`
and `layer=2`?) and what `option=transfer` does. It would be good if
somebody can review it and/or comment in the test.
Side note: The Bash script tests (test cases, test files) are really easy
to create. Just look at r65485. They have a lot of problems and the
solution is not scalable but it is better than no test!
