#2621: r.random.cell should use NULL instead of 0
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: | Platform: Unspecified
Cpu: Unspecified |
It seems that r.random.cell is using 0 to mark empty areas instead of
using proper NULL values.
It is easy fixable by r.nulls call, still it should be fixed.
If it is a desired behaviour, documentation should be updated to state it.
it.
New description:
It seems that r.random.cells is using 0 to mark empty areas instead of
It is easy fixable by r.null call, still it should be fixed.
#2621: r.random.cells should use NULL instead of 0
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: svn-releasebranch70
Keywords: r.random.cells | Platform: Unspecified
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:2 neteler]:
> * Backport to relbranch7
I would say - no. It changes behaviour of module. 7.0.x shouldn't change
such things as it might break some scripts relaying on consistency of 7.0.
Cpu: Unspecified |
Comment(by neteler):
G7.1 manual updated in r65024.
Replying to [comment:3 marisn]:
Maybe. However, the 7.0 manual states "The cells are numbered from 1 to
the
numbers of cells generated." which is not true.
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:4 neteler]:
the
Then the manual needs to be fixed. (It also doesn't state that empty cells
have NULLs thus manual is not contradicting current behaviour.)
How about adding a simple sentence "Empty cells are marked with 0 (will be
changed to NULL in GRASS GIS 7.1.0 release)."?
I would say - fix documentation, add to GRASS 7.1 changes and close this
issue.
