[GRASS-dev] [GRASS GIS] #2628: db.login does not ask for password as PostgreSQL database driver manual page says
page says
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Keywords: postgres | Platform: Linux
      Cpu: Unspecified |
The ''PostgreSQL DATABASE DRIVER'' manual page
(http://grass.osgeo.org/grass70/manuals/grass-pg.html) says:
# example for connecting to a PostgreSQL server:
db.connect driver=pg database="host=myserver.osgeo.org,dbname=mydb"
# password is asked interactively if not specified:
db.login user=myname [pass=secret]
db.connect -p
db.tables -p
I noticed:
So I tried:
db.login user=docker
But then I got:
> db.connect -p
driver: pg
database: host=localhost,port=25432,dbname=gis
schema:
group:
> db.tables -p
DBMI-PostgreSQL driver error:
Connection failed.
fe_sendauth: no password supplied
Connection failed.
I was not prompted for the password at any point. So it seems that either
the manual page is wrong or `db.connect` does not work as expected.
I think that I actually got the `db.tables` error message ("no password
supplied") twice as presented above.
Setting the password in command line works (but of course exposes the
password in the bash history file).
I don't think this is related to #2626 or #2627. I don't know if it is
related to #1951.
By the way, ''PostgreSQL DATABASE DRIVER'' title should be probably
changed to ''PostgreSQL database driver'' (better typography, no reason
for all uppercase).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2628&gt;
page says
Keywords: db.login, postgres | Platform: Linux
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: postgres => db.login, postgres
Ticket URL: <http://trac.osgeo.org/grass/ticket/2628#comment:1&gt;
page says
      Cpu: Unspecified |
Comment(by neteler):
Replying to [ticket:2628 wenzeslaus]:
either the manual page is wrong or `db.connect` does not work as expected.
The interactive password prompting was removed in r32551. See also
comment:6:ticket:1951
... a major security flaw.
related to #1951.
for all uppercase).
(Not sure where that is but please just fix it).
BTW: see also #2147
Ticket URL: <http://trac.osgeo.org/grass/ticket/2628#comment:2&gt;
