[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
  Reporter: pvanbosgeo | Owner: grass-dev@…
  Priority: normal | Milestone: 7.0.3
Component: Vector | Version: unspecified
Resolution: | Keywords:
Comment (by mlennert):
Try the attached patch. This gives access to the v.db.select GUI, not a
simplified version. An option would be to declare this as "Export
attributes to csv file" and make separator=comma the default. Otherwise a
wrapper module would be needed which provides most options as defaults,
but then leaves less flexibility in terms of output formats.
Personally, I would prefer to just provide the standard v.db.select
interface.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2632#comment:4&gt;
