[GRASS-dev] [GRASS GIS] #2632: option in context menu to export vector attribute table
  Reporter: pvanbosgeo | Owner: grass-dev@…
  Priority: normal | Milestone: 7.0.3
Component: Vector | Version: unspecified
Resolution: | Keywords:
Comment (by mlennert):
I added a second patch that puts the (IMHO) main options of v.db.select
(map, column separator, output file) into a "Main choices" tab. I think
this should be enough to make exporting attributes easier, without having
to code a separate simplified GUI. Not sure if "Main choices" is the best
choice of names for that tab, though. Any better ideas are more than
welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2632#comment:5&gt;
welcome.
Thanks. Unfortunately, I am not sure how to apply/test that patch, is there
a description / grass wiki page somewhere that explains?
    v.db.select
    think
    having
    the best
      welcome.
there a description / grass wiki page somewhere that explains?
https://grasswiki.osgeo.org/wiki/Patches
For the GUI part (export_attributes.patch) you can also copy the changes manually into gui/wxpython/lmgr/layertree.py in your GRASS installation directory (GISBASE).
For the v.db.select change you need to patch (or apply manually - there are not that many changes) and then recompile the module.
Moritz
On Tue, Dec 22, 2015 at 5:26 PM, Moritz Lennert <
    v.db.select
    think
    having
    the best
      welcome.
Thanks Moritz, this works perfectly. This is really a very welcome
addition, I hope this can be incorporated.
Thanks. My problem was that I didn't recognized the format.. which looked
suspiciously as html. Which it was, I accidentally saved the webpage of the
patch instead of the patch file itself.
Moritz
On Wed, Dec 23, 2015 at 10:50 AM, Paulo van Breugel
I have updated the Wiki page yesterday and now, adding among other
stuff the new section:
https://grasswiki.osgeo.org/wiki/Patches#Downloading_patches_from_SVN
Feel free to further improve the page.
the
The alternative (and more direct) way to download is to click the little
download icon next to the link. But not sure it is worth adding that?
On Wed, Dec 23, 2015 at 1:20 PM, Paulo van Breugel
Why not. Just go ahead...
Done, including a screenshot with example of a link
