[GRASS-dev] [GRASS GIS] #2636: v.buffer, allow selection of columns for opts "distance", "minordistance", and "angle"
and "angle"
Reporter: isaacullah | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: svn-releasebranch70
Keywords: v.buffer, columns | Platform: Linux
      Cpu: x86-64 |
Currently, v.buffer only allows a column selection for single radius (opt
"column"), but allows the creation of "oblong" buffers using the manual
entry opts "distance", "minordistance", and "angle". v.buffer would be a
lot more useful if these could all simply be column selectable too. For
example, if I have a large vector points file of archaeological site
locations, and I have BOTH a length and width column (and, potentially, a
"site axis direction" column too), then I could make a "buffer" map of the
actual site size and orientation. Currently, in v.buffer, I can only use a
calculated "average" site radius column, and make circular buffers for
these sites.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2636&gt;
