[GRASS-dev] [GRASS GIS] #2637: Get direction raster in clockwise degrees starting from the North
  Reporter: cgravelm | Owner: grass-dev@…
  Priority: normal | Milestone: 7.4.1
Component: Raster | Version: 7.0.0
Resolution: | Keywords:
       CPU: Unspecified | Platform: MacOSX
Comment (by hellik):
Replying to [comment:22 mmetz]:
> Replying to [comment:21 cmbarton]:
> > Such a flag would still be useful for a variety of applications and
should not interfere with other modules if the default behavior remains
the same.
> Such a flag would be easy to implement, but a clear definition of aspect
with regard to zero or small slope is currently missing. Generally, for
zero slope, zero aspect is produced, i.e. a value of zero does not mean
East, but zero slope, while East is encoded as 360 degrees. However, if
min_slope is > 0 and slope < min_slope, slope is set to zero, but aspect
is set to NULL. This is not consistent. Therefore I suggest to produce
zero aspect for zero slope or if slope is < min_slope. NULL is then
reserved for those cells where slope and aspect can not be computed. This
also means that when converting CCW from East to CW from North, North must
be encoded as 360 degrees, not 0 degrees.
sounds reasonable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2637#comment:23&gt;
