[GRASS-dev] [GRASS GIS] #2637: Get direction raster in clockwise degrees starting from the North
  Reporter: cgravelm | Owner: grass-dev@…
  Priority: normal | Milestone: 7.4.1
Component: Raster | Version: 7.0.0
Resolution: | Keywords:
       CPU: Unspecified | Platform: MacOSX
Comment (by hellik):
Replying to [comment:34 mmetz]:
> Replying to [comment:33 hellik]:
> > Replying to [comment:32 neteler]:
> > > Replying to [comment:31 cmbarton]:
> > > > Thanks! Great news.
> > > Please report if it works ok (It may be a backport candidate).
> > tested it a bit; seems to work so far.
> > the only thing for improving seems to assign a working raster color
scheme for this new aspect type map.
> > as far as what I've seen, the result raster map is black.
I mean the result map where the color scheme is automatically set by
r.slope.aspect (see attached: aspect_nflag.png
> The current aspect color scheme is
> 0% black
> 50% white
> 100% black
> assuming that aspect is in degrees (CCW from East or CW from North), a
color scheme like
> 0 black
> 180 white
> 360 black
> should work.
this scheme looks good, see attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/2637#comment:35&gt;
