#2646: mac OSX - wxpython 3 (64 bit) create histogram of raster map fails to
start
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
From the wxpytho gui -> Analyze map -> create histogram of raster map
the widget doesn't load, the following log is printed in the shell (full
debug enabled) :
GRASS 7.1.svn (NAD83_UTM_18N):~ > GUI D3/5: BaseToolbar.OnTool(): id = 179
GUI D1/5: Map.__init__(): None
D1/5: grass.script.core.start_command(): g.tempfile -d pid=90304
D1/5: G_set_program_name(): g.tempfile
D2/5: G_file_name(): path = /Users/epi/grass7data/NAD83_UTM_18N/PERMANENT
/Users/epi/grass7data/NAD83_UTM_18N/PERMANENT/.tmp/epimac.local/90304.0
D1/5: grass.script.core.start_command(): g.gisenv -n
D1/5: G_set_program_name(): g.gisenv
D2/5: G_option_to_separator(): key = separator -> sep = '
GUI D1/5: gcmd.RunCommand(): g.proj -p
D1/5: grass.script.core.start_command(): g.proj -p
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.043165 sec)
GUI D3/5: gcmd.RunCommand(): return stdout
'-PROJ_INFO-------------------------------------------------
name : Universal Transverse Mercator
proj : utm
datum : nad83
ellps : grs80
zone : 18
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
File "/usr/local/grass-7.1.svn/gui/wxpython/mapdisp/frame.py", line
1104, in OnHistogramPyPlot
win = HistogramPlotFrame(parent = self, rasterList = raster)
File "/usr/local/grass-7.1.svn/gui/wxpython/wxplot/histogram.py", line
39, in __init__
BasePlotFrame.__init__(self, parent, size = size, **kwargs)
File "/usr/local/grass-7.1.svn/gui/wxpython/wxplot/base.py", line 88, in
__init__
self.client = plot.PlotCanvas(self)
File
"/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7
/site-packages/wx-3.0-osx_cocoa/wx/lib/plot.py", line 598, in __init__
self.HandCursor = wx.Cursor(Hand.GetImage())
File
/site-packages/wx-3.0-osx_cocoa/wx/_gdi.py", line 1502, in __init__
_gdi_.Cursor_swiginit(self,_gdi_.new_Cursor(*args, **kwargs))
TypeError: Required argument 'type' (pos 2) not found
Ticket URL: <https://trac.osgeo.org/grass/ticket/2646>
