[GRASS-dev] [GRASS GIS] #2647: mac OSX - wxpython 3 (64 bit) - ps.map fails to generate map preiew
Reporter: epifanio | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.1.0
Component: Ps.map | Version: svn-trunk
Keywords: | Platform: MacOSX
      Cpu: x86-64 |
Trying to generate a simple pdf (single raster map + legend) the gui wx
map composer freeze with the following log in the shell:
GUI D1/5: gcmd.CommandThread(): ps.map --overwrite
input=/Users/epi/grass7data/NAD83_UTM_18N/PERMANENT/.tmp/epimac.local/90304.1
output=/Users/epi/grass7data/NAD83_UTM_18N/PERMANENT/.tmp/epimac.local/90304.2
GUI D1/5: gcmd.RunCommand(): g.region rows=947 cols=1014
D1/5: grass.script.core.start_command(): g.region rows=947 cols=1014
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.048446 sec)
Apr 5 20:04:39 epimac.local Python[90304] <Error>:
CGContextRestoreGState: invalid context 0x0. This is a serious error. This
application, or a library it uses, is using an invalid context and is
thereby contributing to an overall degradation of system stability and
reliability. This notice is a courtesy: please fix this problem. It will
become a fatal error in an upcoming update.
   File "/usr/local/grass-7.1.svn/gui/wxpython/psmap/frame.py", line 352,
in OnCmdDone
     im.save(self.imgName, format = 'PNG')
   File "build/bdist.macosx-10.10-intel/egg/PIL/Image.py", line 1653, in
save
     raise ValueError("unknown transformation method")
   File "build/bdist.macosx-10.10-intel/egg/PIL/EpsImagePlugin.py", line
336, in load
     fp.write("grestore end\n")
143, in Ghostscript
     length = fp.tell()
   File
"/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py",
line 710, in __init__
     errread, errwrite)
   File
line 1335, in _execute_child
     raise child_exception
OSError: [Errno 2] No such file or directory
Ticket URL: <https://trac.osgeo.org/grass/ticket/2647&gt;
Component: wxGUI | Version: svn-trunk
Keywords: cartographic composer | Platform: MacOSX
      Cpu: x86-64 |
Changes (by annakrat):
  * keywords: => cartographic composer
  * component: Ps.map => wxGUI
Comment:
Do you have Ghostscript installed and on the path?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2647#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: cartographic composer
  Platform: MacOSX | Cpu: x86-64
Changes (by epifanio):
  * status: new => closed
  * resolution: => fixed
Comment:
Ghostscript was installed by homebrew, but for some reason not linked in
the path.
I forced the link and now both preview and ps output works fine
Ticket URL: <http://trac.osgeo.org/grass/ticket/2647#comment:2&gt;
