GDAL
April 8, 2015, 6:06am
1
#2649: r.to.vect diagonals defect fixed
Reporter: byronbest | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: x86-64 |
fails to break lines when value changes along diagonals
patch for 7.0.0 attached
tested in 6.4.3 on Amazon
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
April 8, 2015, 6:16am
2
Component: Raster | Version: unspecified
Keywords: | Platform: All
Cpu: x86-64 |
Changes (by byronbest):
* platform: Unspecified => All
* component: Default => Raster
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649#comment:1> ;
GDAL
April 20, 2015, 11:40am
3
Keywords: r.to.vect | Platform: All
Cpu: x86-64 |
Changes (by neteler):
* keywords: => r.to.vect
Comment:
Can you please post a test case/screenshot to better understand the
problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649#comment:2> ;
GDAL
April 20, 2015, 2:17pm
4
Cpu: x86-64 |
Comment(by byronbest):
Consider the result of r.drain, which is an already-thinned line of pixel
centres, obviously in "runs" of x,y moving +/- 1 in x and/or y. We'd like
for the runs be "collapsed" into only the corners where the direction
changes. Further, we'd like that running the stream on another grid
respect that we also need the corners where the color or value on the
resulting line changes. The segments will be given the color of the pixel
under the second of every pair.
r.to.vect already handles these runs when they are straight in the x or y,
but not in diagonals where both x and y change.
The attached before/after screen shots show where this has become a
visible defect.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649#comment:3> ;
GDAL
April 21, 2015, 3:27pm
5
Cpu: x86-64 |
Comment(by neteler):
All the tiff attachments seem to be broken (I tried two browsers), please
use PNG format for screenshots.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649#comment:4> ;
GDAL
June 16, 2015, 10:08am
6
Resolution: | Keywords: r.to.vect
CPU: x86-64 | Platform: All
Comment (by mlennert):
Has anyone been able to take a closer look at this patch ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2649#comment:5> ;
