GDAL
April 8, 2015, 6:57am
1
#2650: v.in.ascii - dropdown menu - gui components doesn't get update
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: wxpython | Platform: MacOSX
Cpu: OSX/Intel |
'separator' and 'text' parameter are not updated in the command when an
option is selected from the relative dropdown menu. To trig the update,
an extra typing in the option textbox is required.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
April 8, 2015, 1:36pm
2
Cpu: OSX/Intel |
Comment(by annakrat):
I hoped I can reproduce it on my Ubuntu with wxPython3 but it works for
me. What about the 'format' parameter, does it fail too?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:1> ;
GDAL
April 8, 2015, 2:05pm
3
Cpu: OSX/Intel |
Comment(by epifanio):
On ubuntu it works fine. The problem is on OSX.
I tried the format parameter and it works as expected. the issue are only
on "separator" and "text" parameters.
Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:2> ;
GDAL
April 8, 2015, 2:07pm
4
Cpu: OSX/Intel |
Replying to [comment:2 epifanio]:
only on "separator" and "text" parameters.
> Thanks!
that's really strange, these all should be the same widgets
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:3> ;
GDAL
April 8, 2015, 10:29pm
5
Cpu: OSX/Intel |
I attached a short vide to show the behaviour. I agree it's strange and
they are all the same type of widget.
http://144.76.93.231/shared/debugging/grassgui_v-in-ascii.mp4
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:4> ;
GDAL
April 9, 2015, 2:42am
6
Cpu: OSX/Intel |
Replying to [comment:4 epifanio]:
Please try r65027 in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:5> ;
GDAL
April 9, 2015, 2:54am
7
Type: defect | Status: closed
Resolution: fixed | Keywords: wxpython
Platform: MacOSX | Cpu: OSX/Intel
Changes (by epifanio):
* status: new => closed
* resolution: => fixed
Comment:
It works grear, thank you!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:6> ;
GDAL
April 9, 2015, 2:57am
8
Backported in r65028.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2650#comment:7> ;
