#2652: v.in.e00
Reporter: templar112 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: 7.0.0
Keywords: | Platform: MSWindows 8
Cpu: x86-64 |
I'm new to Grass GIS, but it appears that the v.in.e00 script has not been
updated to match the new input parameters format.
I downloaded an E00 file from http://www.geocomm.com/ just as a test to
see if I could import some data.
The input parameters it expects are as follows:
options['file'] which should be options['input']
options['vect'] which should be options['output']
Also, the script requires the following additional files:
avcimport.exe
e00conv.exe
The former file exists under the "extrabin" folder, but I had to download
the e00conv binary myself. Maybe it should be included as well?
The next issue is the following line: #try_remove(info)
It says that info is not a valid global object or something like that.
Finally, the following statement also doesn't work:
# write cmd history:
grass.vector_history(name)
It complains about vector_history not being a valid function.
I don't have the expertise to fix this, but maybe some with python and
Grass knowledge can!
