[GRASS-dev] [GRASS GIS] #2654: r.thin crashes
Reporter: pairmand | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: r.thin | Platform: MSWindows 7
      Cpu: x86-64 |
r.thin crashes (Windows message that GRASS 7 has stopped working).
The input was first imported from the attached Erdas Imagine file into a
new location (EPSG:2193), then thinned using the following commands;
r.in.gdal input=D:\temp_work\temukaSub_rasterEdges.img output=rasterEdges
--overwrite -e
r.thin --overwrite --quiet input=rasterEdges output=thinnedRaster
iterations=200
If the If the extent is not set using -e on the import, then it fails with
"Unable to find bounding box for lines" but doesn't crash.
I have tried the same on Linux machine and in that case the "crash" has a
message: "Error writing temporary file".
It has identical to above if the extent has not been defined (earlier
versions of GRASS seemed to handle this).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654&gt;
      Cpu: x86-64 |
Comment(by neteler):
Please post here also the output of
g.region -p
Additionally, is there enough free space on the disk?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2654#comment:1&gt;
      Cpu: x86-64 |
Comment(by marisn):
I am somehow unable to reproduce described "crash". If it is a real crash
not just a stop with error message, please, run r.thin from gdb and
afterwards also under valgrind and provide obtained backtraces.
Be ware - there was a serious flaw in documentation - r.thin is thinning
non-null cells instead of non-zero cells, as documentation states. It is
necessary to run r.null setnull=0 on your imported data otherwise thinning
is useless.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654#comment:2&gt;
      Cpu: x86-64 |
Comment(by pairmand):
Thank you both for your help - I think it was actually multiple unrelated
problems.
If I create a new location/mapset then g.region -p produces;
g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: nzgd2k
ellipsoid: grs80
north: 1
south: 0
west: 0
east: 1
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
(Mon Apr 20 11:50:24 2015) Command finished (0 sec)
If I then import the Imagine file with extend region and repeat I get;
output=temukaSub_rasterEdges -e
WARNING: Datum <NZGD2000_NTv2> not recognised by GRASS and no parameters
found
Raster map <temukaSub_rasterEdges> created.
Region for the current mapset updated
r.in.gdal complete.
(Mon Apr 20 11:53:07 2015) Command finished (0 sec)
(Mon Apr 20 11:53:20 2015)
g.region -p
zone: 0
datum: nzgd2k
ellipsoid: grs80
north: 5117010
south: 0
west: 0
east: 1474010
nsres: 1
ewres: 1
rows: 5117010
cols: 1474010
cells: 7542523910100
(Mon Apr 20 11:53:20 2015) Command finished (0 sec)
That is, the map coordinates seem to be set to the north east corner but
south, west, cols and rows are all incorrect. This appears to be a bug
importing from the Imagine file using the gdal importer. If I try and thin
at this point then the thin crashes - see screenshot.
[[Image(http://trac.osgeo.org/grass/attachment/ticket/2654/GrassCrash.JPG)]]
However, if I use g.region to correct the above I get a result that looks
good;
g.region raster=temukaSub_rasterEdges
(Mon Apr 20 12:03:08 2015) Command finished (0 sec)
(Mon Apr 20 12:03:22 2015)
g.region -p
zone: 0
datum: nzgd2k
ellipsoid: grs80
north: 5117010
south: 5108000
west: 1463000
east: 1474010
nsres: 10
ewres: 10
rows: 901
cols: 1101
cells: 992001
(Mon Apr 20 12:03:22 2015) Command finished (0 sec)
At this point running r.thin still produces an error and only appears to
have processed the middle section of the image.
Thinning not completed, consider to increase 'iterations' parameter.
Output map 901 rows X 1101 columns
Window 901 rows X 1101 columns
(Mon Apr 20 12:04:46 2015) Command finished (17 sec)
Setting 0 as null cells fixes that problem also;
r.null map=temukaSub_rasterEdges setnull=0
(Mon Apr 20 12:06:49 2015) Command finished (0 sec)
(Mon Apr 20 12:07:20 2015)
r.thin --overwrite input=temukaSub_rasterEdges@canTest
output=temukaThinned
Raster map <temukaSub_rasterEdges@canTest> - 901 rows X 1101 columns
Bounding box: l = 2, r = 1102, t = 2, b = 902
Pass number 1
Deleted 68577 pixels
Pass number 2
Deleted 2270 pixels
Pass number 3
Deleted 37 pixels
Pass number 4
Deleted 0 pixels
Thinning completed successfully.
(Mon Apr 20 12:07:21 2015) Command finished (0 sec)
So I'm now a happy camper - but suggest there is a bug in the raster
importer, in that it doesn't set the extent correctly, and the
documentation of r.thin definitely needs to clarify that it is working on
nulls not zeros.
Thanks again for your help.
David
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654#comment:3&gt;
      Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:3 pairmand]:
unrelated problems.
> g.region -p
> zone: 0
> datum: nzgd2k
> ellipsoid: grs80
> north: 1
> south: 0
> west: 0
> east: 1
> nsres: 1
> ewres: 1
> rows: 1
> cols: 1
> cells: 1
found
> r.in.gdal complete.
> g.region -p
> zone: 0
> datum: nzgd2k
> ellipsoid: grs80
> north: 5117010
> south: 0
> west: 0
> east: 1474010
> nsres: 1
> ewres: 1
> rows: 5117010
> cols: 1474010
The man page of r.in.gdal says about the '-e' flag: "Extend region extents
based on new dataset". It does not say: Set the computational region to
the extents of the imported map. So, the behaviour is conform to what it
announces: your region is '''extended''' so that it also englobes the
imported map.
I think that r.thin should not crash if there are no null values, so this
is a bug, but AFAICS there is no bug in r.in.gdal.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654#comment:4&gt;
      Cpu: x86-64 |
Comment(by marisn):
Replying to [comment:4 mlennert]:
this is a bug, but AFAICS there is no bug in r.in.gdal.
> Moritz
I have been unable to reproduce crash on my Linux machine so far. As far
as I could understand, the crash is not rising from no lines to thin (lack
of null values) but from running out of memory / disk space due to
enormous computational region.
I have updated documentation to match module behaviour in r65083 (0 vs
null) and removed use of unused error_prefix in r65101
The error message "Error writing temporary file" indicates running out of
disk space. It is not a crash. Unless someone manages to reproduce crash
on Linux (and provide output of gdb and valgrind!), I would tend to close
this issue as caused by too large computational region.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2654#comment:5&gt;
