[GRASS-dev] [GRASS GIS] #2658: [PATCH] v.to.db compactness gives wrong results in feet location
  Reporter: annakrat | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.3
Component: LibGIS | Version: svn-releasebranch70
Resolution: | Keywords: v.to.db, units, area, compactness
       CPU: Unspecified | Platform: All
Changes (by annakrat):
* priority: major => normal
Comment:
Replying to [comment:6 mlennert]:
> Replying to [comment:5 annakrat]:
> > Replying to [comment:4 neteler]:
> > > Will you apply the patch?
> > I applied the patch, but needs more testing.
> As mentioned, the patch has some side effects in terms of weird results
in terms of decimals.
> I agree that it is better than leaving as is, but in the long run,
changing area calculations to always return current location units might a
better idea.
> This would entail changing
[https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/area.c#L159
G_area_of_polygon()] and this will probably be quite invasive as any
library function or module calling this function would have to be updated.
> In the meantime this should be backported IMHO.
Done in r67327.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2658#comment:7&gt;
