[GRASS-dev] [GRASS GIS] #2662: v.in.proj crashes on Windows
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.0.1
Component: LibGIS | Version: svn-releasebranch70
Keywords: v.in.proj, r.in.proj | CPU: Unspecified
Platform: Unspecified |
`v.in.proj` crashes on Windows (epsg:4326 -> epsg:5514)
D2/5: file open: read (mode = r)
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 3
D3/5: region item: zone: 0
D3/5: region item: north: 935275:00:27.10224S
ERROR: Syntax error in cell header
on source:grass/trunk/vector/v.in.ogr/main.c#L591
This issue has been apparently fixed in trunk (where it works). The last
change of `get_window.c` is from 2014-12-29. Any idea when it was fixed
(and backported to relbr70)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2662&gt;
Resolution: | Keywords: v.in.proj, r.in.proj
Comment (by neteler):
Not sure if that matters but there is this coverity scan report:
*** CID 1262561: Unbounded source buffer (STRING_SIZE)
/lib/gis/get_window.c: 65 in G_get_window()
59 if (regvar) {
60 char **tokens = G_tokenize(regvar, ";");
61 G__read_Cell_head_array(tokens, &st->dbwindow, 0);
62 G_free_tokens(tokens);
63 }
64 else {
>>> Assigning: "wind" = "getenv". "wind" is now tainted.
65 char *wind = getenv("WIND_OVERRIDE");
66 if (wind)
67 G_get_element_window(&st->dbwindow, "windows", wind,
G_mapset());
68 else
69 G_get_element_window(&st->dbwindow, "", "WIND", G_mapset());
70 }
Ticket URL: <http://trac.osgeo.org/grass/ticket/2662#comment:1&gt;
Comment (by martinl):
I can confirm this bug also in 7.0.1svn.
BTW, daily winGRASS builds for 7.0.1svn are newly available at (1)
(1) http://wingrass.fsv.cvut.cz/grass70/
Ticket URL: <http://trac.osgeo.org/grass/ticket/2662#comment:2&gt;
#2662: v.in.proj crashes on Windows (v.in.ogr problem)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2662#comment:3&gt;
With latest build (1) I cannot reproduce this issue, `v.in.proj`
successfully imports shapefile in EPSG:4326 to location in EPSG:5514.
Does anybody here can also test it? Thanks.
(1)
http://wingrass.fsv.cvut.cz/grass70/WinGRASS-7.0.1svn-r65457-45-Setup.exe
Ticket URL: <https://trac.osgeo.org/grass/ticket/2662#comment:4&gt;
Comment (by hellik):
Replying to [comment:4 martinl]:
> (1)
any test data set?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2662#comment:5&gt;
Replying to [comment:5 hellik]:
> any test data set?
Just try to import data using v.in.proj to the location with different
srs...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2662#comment:6&gt;
Replying to [comment:6 martinl]:
> > any test data set?
srs...
tested with
GRASS Version: 7.1.svn
GRASS SVN revision: 65460
Build date: 2015-06-14
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
C:\tmp>ogrinfo -al vienna.shp
INFO: Open of `vienna.shp'
       using driver `ESRI Shapefile' successful.
Layer name: vienna
Geometry: Polygon
Feature Count: 1
Extent: (16.289482, 48.155973) - (16.463998, 48.275724)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
     DATUM["WGS_1984",
         SPHEROID["WGS_84",6378137.0,298.257223563]],
     PRIMEM["Greenwich",0.0],
     UNIT["Degree",0.0174532925199433]]
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : tmerc
datum : hermannskogel
ellps : bessel
lat_0 : 0
lon_0 : 16.33333333333333
k : 1
x_0 : 750000
y_0 : 0
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31286
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
(Sun Jun 14 21:56:04 2015)
v.in.proj --verbose input_file=C:\tmp\vienna.shp output=vienna
extents=input
(Sun Jun 14 21:56:09 2015) Befehl ausgeführt (5 Sek)
seems to work
Helmut
p.s. any chance to get back OSGeo4W-winGRASS7.0.x-daiylies; no chance to
test here the standalone winGRASS7.0.x-daiylies
p.p.s https://trac.osgeo.org/grass/ticket/2634 is quite annyoing and makes
winGRASS-trunk quite unusable for me ...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2662#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.proj, r.in.proj
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:7 hellik]:
please not that this bug has been possible to reproduce only in relbr70,
not trunk
there are already there (1)
Closing this ticket since it seems to be "fixed".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2662#comment:8&gt;
