[GRASS-dev] [GRASS GIS] #2669: v.net.iso: different results depending on direction
  Reporter: mlennert | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-trunk
Resolution: | Keywords: network v.net.iso direction cost
Comment (by mmetz):
Replying to [comment:1 mlennert]:
> Apparently the problem arises when lines are diagonal (in comparison to
NS or EW direction). Here's a reproducible testcase:
> * horizontal
> v.in.lines in=- out=testline sep=, --o << EOF
> 610000,225000
> 680000,225000
> EOF
> echo "645000|225000" | v.in.ascii in=- out=testpoint --o
> v.net testline point=testpoint op=connect thresh=500 out=testnet --o
> v.db.addtable testnet col="length double precision, cost double
precision"
> v.to.db testnet op=length col=length
> v.db.update testnet col=cost qcol="length/(100*1000/60)"
> v.net.iso testnet out=testiso center_cats=1-999 costs=10,20,30,40
arc_column=cost --o
> * diagonal
> 610000,200000
> 680000,300000
> EOF
> v.net -s testline point=testpoint op=connect thresh=50000 out=testnet
--o
precision"
costs=10,20,30,40,50,60,70 arc_column=cost --o
> * vectical
> 645000,200000
> 645000,300000
> EOF
> echo "645000|250000" | v.in.ascii in=- out=testpoint --o
--o
precision"
> I'll attach the respective images. In the diagonal case, the isochrones
are much closer towards the South-West (~37km - using the wxgui measuring
tool - to reach the beginning of cat=8) than towards the North-East (~78km
to reach the beginning of cat=8). As cost is defined via only one column,
it should be identical in both directions.
The problem/reason is that the length values in the length column are not
what you expect. v.net has broken the line where the point has been
snapped to. The two new lines have the same category values like the old
line, i.e. identical category values, thus one common entry in the
attribute table. The length value in the attribute table is thus the sum
of the lengths of the two lines. You get results as expected with e.g.
610000,200000
680000,300000
EOF
v.net -s testline point=testpoint op=connect thresh=50000 out=testnet_1
--o
v.category in=testnet_1 out=testnet type=line op=add layer=3
v.db.addtable testnet col="length double precision, cost double precision"
layer=3
v.to.db testnet op=length col=length layer=3
v.db.update testnet col=cost qcol="length/(100*1000/60)" layer=3
v.net.iso testnet out=testiso center_cats=1-999 costs=10,20,30,40,50,60,70
arc_column=cost arc_layer=3 --o
Here, unique categories are created with v.category in a new layer 3.
v.net keeps the original categories when splitting up a line because these
categories can encode important information such as type of the road or
speed limit which in turn might be needed for cost calculation. An example
is given in the manual for v.net.path.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2669#comment:6&gt;
