[GRASS-dev] [GRASS GIS] #2681: Remove legacy meaning of LOCATION variable
  Reporter: wenzeslaus | Owner: grass-dev@…
      Type: task | Status: new
  Priority: blocker | Milestone: 8.0.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init, grass.py, interface, CLI,
       CPU: | environment variables
  Unspecified | Platform: All
Comment (by wenzeslaus):
As for using the name `LOCATION` to mean "full path to a mapset",
remaining places are the following:
The main in the variable defined for the shell in `lib/init/grass.py`.
That seems to be only interface-related usage. I think this should be
replaced by something else like `MAPSET_PATH` or `FULL_MAPSET`.
There is something in `lib/init/README` which would likely use general
update.
There might be some bad examples in existing code, these two may qualify:
`raster/r.mapcalc/testsuite/const_map_test.sh` and
`testsuite/raster/raster_md5test.sh`.
There are places which need deeper look, namely `lib/gis/make_mapset.c`
and `lib/gis/location.c`.
* source:grass/trunk/lib/init/grass.py
* source:grass/trunk/lib/init/README
* source:grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
* source:grass/trunk/testsuite/raster/raster_md5test.sh
* source:grass/trunk/lib/gis/make_mapset.c
* source:grass/trunk/lib/gis/location.c
Ticket URL: <https://trac.osgeo.org/grass/ticket/2681#comment:5&gt;
