#2681: Remove legacy meaning of LOCATION variable
Reporter: wenzeslaus | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 8.0.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init, grass.py, interface, CLI,
CPU: | environment variables
Unspecified | Platform: All
Comment (by wenzeslaus):
Here is the status of the files identified in the comment:5:
Resolved:
* source:grass/trunk/lib/init/README - Done, text removed (r73355)
* source:grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh - Done,
replaced by MAPSET_PATH, test is running (r73357)
* source:grass/trunk/testsuite/raster/raster_md5test.sh - Done, replaced
Resolved, needs change for 8.0:
* source:grass/trunk/lib/init/grass.py - Done, replaced by MAPSET_PATH
(LOCATION left for 7.8), LOCATION_NAME in doc replaced by LOCATION
(r73352, r73353, r73354, r73356)
Unresolved:
* source:grass/trunk/lib/gis/location.c - LOCATION used in error message
in G_location_path(), probably "location path" or "Location path" would be
more appropriate here
* source:grass/trunk/lib/gis/make_mapset.c - I would expect LOCATION_NAME
here, but it says LOCATION. I'm not sure what it does or what it is
supposed to do. Comes all the way from r21496.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2681#comment:10>
