[GRASS-dev] [GRASS GIS] #2683: grass 7 doesn't start in text mode on CentOS 7
  Reporter: morenocomelli | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.3
Component: Startup | Version: 7.0.0
Resolution: | Keywords: centos
Comment (by morenocomelli):
Same problem with GRASS 7.0.2 and GRASS 7.1.[[BR]]
GRASS looks for location and mapset, and since there are none defined when
starting the first time, the error appears (in text mode only).[[BR]]
If mapset and location are created through gui, at next start in text mode
they're the default settings. An other option is to create the
/root/.grass7/rc file with proper parameters and the missing part of dir
tree (the supposed dirs with database, location and mapset).
Replying to [ticket:2683 morenocomelli]:
> I'm trying to start grass 7 on CentOS 7 in text mode (Grass 6.4.4
installed via yum works correctly).
> On Centos with GUI:
> # grass70 -text
> ERROR: Unable to start GRASS. You can:
> - Launch GRASS with '-gui' switch (`grass70 -gui`)
> - Create manually GISRC file (/root/.grass7/rc)
> - Launch GRASS with path to the location/mapset as an argument
(`grass70 /path/to/location/mapset`)
> Exiting...
> On CentOS without GUI:
> # grass70 -text
> WARNING: Searched for a web browser, but none found
> Exiting...
> #grass70
> Starting GRASS GIS...
> WARNING: It appears that the X Windows system is not active.
> A graphical based user interface is not supported.
> Switching to text based interface mode.
> Hit RETURN to continue
> ERROR: Path '/home/download/grass-7.0.0/<UNKNOWN>/<UNKNOWN>' doesn't
exist
> Exiting...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2683#comment:5&gt;
