[GRASS-dev] [GRASS GIS] #2685: Add ignore lock flag to grass command
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: normal | Milestone: 7.1.0
Component: Startup | Version: svn-trunk
Keywords: init, grass.py, CLI | CPU: Unspecified
Platform: Unspecified |
In `grass.py` we have `-f` flag to force removal of lock but to read only
commands (list maps in Lacation or Mapset or get region from another
Mapset) there is no need for removal, more precisely, it would be wrong.
The right thing to do is to just ignore that the lock is there. It's up to
the caller that only read only modules are called. Surely this can be used
for parallel processing as well when same rules are applied as would be
applied to parallel processing within GRASS session.
Current `grass71 --help`:
   -f force removal of .gislock if exists (use with care!). Only with
-text flag
Proposed `grass71 --help`:
           Only with -text and --exec flags
   -i ignore presence of .gislock if exists (use with care!)
           Only with -text and --exec flags. Suitable for read only
modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2685&gt;
Resolution: | Keywords: init, grass.py, CLI
Comment (by mlennert):
Wouldn't this mean that every module has to check whether there is a
.gislock ?
You can always create another mapset and read whatever you need from
there, so I don't understand the need for a read-only access to a
particular mapset.
Sounds like a dangerous path to me.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2685#comment:1&gt;
Comment (by wenzeslaus):
Replying to [comment:1 mlennert]:
.gislock ?
No. There would be no check. It is up to the caller. Perhaps the note
about read-only shouldn't be in the parameter explanation, just in a
detailed documentation. Read-only is suggestion or use case here, not
something enforced.
particular mapset.
There is several ways around it. `g.list` can just read from other Mapsets
and `g.mapsets` can give you an (actual) read-only access to other Mapset.
However, the use case here is emulate what you get when you set up GRASS
environment/session manually
("[http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
without starting explicitly]"). You have no checks at all and you can
still access and do anything. Purpose of suggested (`-i`) flag is to skip
the lock check but still benefit from other things `grass.py` is doing
like taking care of "gisrc" file.
`-f` is also dangerous, and on MS Windows or when you set up GRASS
without starting explicitly]") there are no checks at all, so I don't
think it is more dangerous than anything we have now. On the contrary,
with `-i` you would explicitly ask for this dangerous behavior which is
safer then getting it unexpectedly (in an implicit way) with manual setup
of the environment or on MS Windows in general.
These things are what I considered but I might have missed something.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2685#comment:2&gt;
