[GRASS-dev] [GRASS GIS] #2686: r.hazard.flood error output
Reporter: zimbogisgeek | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.1
Component: Python | Version: svn-releasebranch70
Keywords: | CPU: All
Platform: All |
Running r.hazard.flood produces an erroneous map mainly because in the
r.hazard.py script there is a mistake in calculating the final map. The
command that produces the error is
grass.mapcalc("$r_flood_map = $rast1 / $rast1", r_flood_map = r_flood_map,
rast1 = 'r_flood_th')
which should be
  grass.mapcalc("$r_flood_map = $rast1 / $rast2", r_flood_map =
r_flood_map, rast1 = 'r_flood_th', rast2 = 'r_flood')
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686&gt;
Component: Addons | Version: svn-releasebranch70
Resolution: | Keywords: r.hazard.flood
       CPU: All | Platform: All
Changes (by neteler):
* cc: madi (added)
* keywords: => r.hazard.flood
* component: Python => Addons
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:1&gt;
  Priority: normal | Milestone: 7.0.1
Changes (by madi):
* priority: critical => normal
Comment:
Hi, thank you for pointing this out, but does this actually produce an
erroneous result? could you give an example? Thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:2&gt;
Comment (by lucadelu):
Hi Madi, but the code is dividing the same maps
so it return for every pixel 1, is it the right behavior?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:3&gt;
Comment (by madi):
Replying to [comment:3 lucadelu]:
yes, the expected result is a binary map (yes=1, no=null)
madi
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:4&gt;
Comment (by neteler):
Replying to [comment:4 madi]:
The behaviour in question comes from r.mapcalc:
Here a quick test:
r.mapcalc "result = 1/1"
r.univar -g result | grep 'min\|max\|null'
null_cells=0
min=1
max=1
r.mapcalc "result2 = 0/0"
r.info result2 | grep 'min\|max\|null'
  | Range of data: min = NULL max = NULL
r.mapcalc "result3 = null()/null()"
r.info result3 | grep 'min\|max\|null'
Is this what should happen in r.hazard.flood?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:5&gt;
Comment (by madi):
Replying to [comment:5 neteler]:
> Here a quick test:
> null_cells=0
> min=1
> max=1
Precisely so.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:6&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: r.hazard.flood
Changes (by madi):
* status: new => closed
* resolution: => invalid
Comment:
I double checked the code and unless I can't see the obvious it looks
alright to me. Therefore I'm closing this ticket as invalid. Please feel
free to reopen it if something looks amiss. However, the expected result
of this tool is indeed a binary map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686#comment:7&gt;
