[GRASS-dev] [GRASS GIS] #2687: r.info picks map from current Mapset instead of PERMANENT
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.info, mapset, search path, | CPU: x86-64
  PERMANENT |
Platform: Linux |
In the following environment (GRASS Sample NC SPM Location):
> g.mapsets -p
Accessible mapsets:
user1 PERMANENT landsat
> g.list t=rast -m p=land*
landclass96@PERMANENT
landcover_1m@PERMANENT
landuse96_28m@PERMANENT
I can run `r.univar`:
> r.univar landclass96
n: 1554124
minimum: 1
maximum: 7
But `r.info` looks to a wrong Mapset:
> r.info landclass96
WARNING: G__open(read): Unable to open
'/home/vasek/grassdata/nc_spm_08_grass7_tests/user1/cellhd/landclass96':
          No such file or directory
ERROR: Unable to open header file for raster map <landclass96@>
Moreover, there is a `@` character in the `Unable to open...map
<landclass96@>` message.
You can get the same errors by running the automated test suite:
cd /grass/source/code/root
./bin.../grass71 ~/grassdata/nc_spm_08/PERMANENT/ --exec python -m
grass.gunittest.main --location nc_spm_08 --location-type nc
firefox testreport/index.html
firefox testreport/lib/python/gunittest/test_assertions/index.html
You can see the results of automated tests also online:
* http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-06-02-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-06-02-07-00/report_for_nc_spm_08_grass7_nc/raster/r.slope.aspect/test_r_slope_aspect/index.html
[[Image(http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/tests_successful_plot.png,
95%)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687&gt;
Resolution: | Keywords: r.info, mapset, search path,
                         | PERMANENT
       CPU: x86-64 | Platform: Linux
Comment (by glynn):
Replying to [ticket:2687 wenzeslaus]:
> r.info landclass96
This is caused by r65348, which constructs the path before the mapset has
been resolved.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:1&gt;
                         | PERMANENT
Comment (by annakrat):
Any progress on this? If not, I would suggest to revert it for now and
test it properly before reintroducing it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:2&gt;
                         | PERMANENT
Comment (by martinl):
Try r65437
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.info, mapset, search path,
                         | PERMANENT
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 martinl]:
> Try r65437
Thanks, r65437 fixed the issue. Closing.
If somebody wants to test quickly, it can be tested for example with
(`r.info` is used there):
# inside GRASS session in NC SPM
cd ./lib/python/gunittest/testsuite/
python test_module_assertions.py
Just for the record, the missing `G_file_name(path, element, name,
mapset);` call originated in r65348.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:4&gt;
                         | PERMANENT
Comment (by glynn):
> Try r65437
Does the write case need something similar?
More generally, why is "path" being constructed before the mapset has been
determined?
Bear in mind that fully qualified names are valid for output files so long
as the mapset is the current mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:5&gt;
                         | PERMANENT
Replying to [comment:5 glynn]:
been determined?
right, it was not good idea, changed in r65453
Ticket URL: <https://trac.osgeo.org/grass/ticket/2687#comment:6&gt;
