#2693: Error with SQLite path update after moving grass data
Reporter: ffxi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Keywords: sqlite update path move data | CPU: x86-64
Platform: Linux |
The Sqlite path is not completely updated after moving/renaming data :
Eg. /home/test/oldPath -> /home/test/newPath
At every grass init, I use "db.connect" to connect to the correct DB,
using
"$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db"
When I type the command like :
v.info map="my_map"
The correct database path is returned : /home/test/newPath
When I type :
db.describe table="my_map"
I've got the right description.
But when I use a command like :
g.copy map=my_vector,tmp_vector
or
v.out.ogr input="my_map" output=/home/testShape format=ESRI_Shapefile
A SQLITE error mentioning the old path is returned:
ERROR: Unable to open database < /home/test/oldPath >
$ grass70 --version
GRASS GIS 7.0.0
OS : mac os 10.10.3 and Ubuntu 14.04
Grass installed using :
Mac: [homebrew](https://github.com/OSGeo/homebrew-
osgeo4mac/blob/master/Formula/grass-70.rb)
Ubuntu : compiled from source.
Thanks, and sorry if this is a duplicate, i did not found a similar
ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2693>
