[GRASS-dev] [GRASS GIS] #2694: rendering command layer and adding 3d raster layer broken
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: rendering | CPU: Unspecified
Platform: Linux |
Two issues I found with the new rendering with the less often used cases:
1. adding 3D raster layer breaks rendering, although there is no error,
rendering just stops working after that and busy cursors stays there. I
was trying to fix this one, but was not able to get rid of the progress
bar which was still showing up:
Index: core/render.py
--- core/render.py (revision 65443)
+++ core/render.py (working copy)
@@ -472,6 +472,8 @@
          # render map layers if forced
          nlayers = 0
          for layer in self.layers:
+ if layer.GetType() == '3d-raster':
+ continue
              if force or layer.forceRender:
                  nlayers += 1
                  layer.Render(env)
@@ -532,6 +534,8 @@
              if layer.GetType() == 'overlay':
                  continue
+ continue
              if os.path.isfile(layer.mapfile):
                  maps.append(layer.mapfile)
2. Rendering command layers is weird, (un)checking has no effect.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694&gt;
Resolution: | Keywords: rendering
       CPU: Unspecified | Platform: Linux
Comment (by martinl):
Replying to [ticket:2694 annakrat]:
please try out r65450
I would suggest to remove command layers from wxGUI completely, what do
you think?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:1&gt;
  Reporter: annakrat | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* owner: grass-dev@… => martinl
* status: new => assigned
* cc: grass-dev@… (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:2&gt;
Comment (by annakrat):
Replying to [comment:1 martinl]:
error, rendering just stops working after that and busy cursors stays
there. I was trying to fix this one, but was not able to get rid of the
progress bar which was still showing up:
Thank you, works nicely
you think?
Hm, I was actually using it. For example you can have multiple legends
with command layers and you can save them to workspace. But that's
workaround for not having a way to display multiple legends.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:3&gt;
Replying to [comment:3 annakrat]:
do you think?
I realized d.histogram is not working when called from Map Display
toolbar. It seems that it actually uses the command layers.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694#comment:4&gt;
