#2699: g.gui.iclass doesn't run after selecting training areas
Reporter: ThayseNery | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
I have been trying to apply supervised classification using
'''g.gui.iclass''' in GRASS GIS 7.0.1RC1 windows but it doesn't work
properly. What I do:
1) Launch g.gui.iclass
I can open the module by selecting group and imagery subgroup. But when
the windows GRASS Supervised Classification Tool opens, I observed that
name of imagery subgroup is missing. By adding it through select imagery
group I got the following error:
''File "C:\Program Files (x86)\GRASS GIS
7.0.1RC1\gui\wxpython\iclass\toolbars.py", line 163, in <lambda>
lambda event : self.parent.AddBands()),
7.0.1RC1\gui\wxpython\iclass\frame.py", line 513, in AddBands
subgroup=self.g['subgroup'])
7.0.1RC1\etc\python\grass\pydispatch\signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
7.0.1RC1\etc\python\grass\pydispatch\dispatcher.py", line 349, in send
**named
7.0.1RC1\etc\python\grass\pydispatch\robustapply.py", line 60, in
robustApply
return receiver(*arguments, **named)
7.0.1RC1\gui\wxpython\iscatt\controllers.py", line 1111, in GroupSet
self.scatt_mgr.SetBands(bands)
7.0.1RC1\gui\wxpython\iscatt\controllers.py", line 164, in SetBands
i = GetRasterInfo(b)
7.0.1RC1\gui\wxpython\iscatt\iscatt_core.py", line 832, in GetRasterInfo
raise GException("r.info failed:\n%s" % msg)
core.gcmd.GException: r.info failed:
Illegal filename <PERMANENT
>. Character not allowed.''
My file name doesn’t have any special character as it is called feb2014.
Although the imagery subgroup cannot been opened, I am able to:
2) Add RGB map layer
3) Add a class in the class manager and assign a custom color
5) I can digitize new area
But After selecting some training areas, I try to run the model and I got
another error:
7.0.1RC1\gui\wxpython\iclass\frame.py", line 911, in OnRunAnalysis
if self.RunAnalysis():
7.0.1RC1\gui\wxpython\iclass\frame.py", line 922, in RunAnalysis
if not self.CheckInput(group = self.g['group'], vector =
self.trainingAreaVector):
7.0.1RC1\gui\wxpython\iclass\frame.py", line 1087, in CheckInput
rasterInfo = grass.raster_info(groupLayers[0])
7.0.1RC1\etc\python\grass\script\raster.py", line 70, in raster_info
s = read_command('r.info', flags='gre', map=map)
7.0.1RC1\etc\python\grass\script\core.py", line 427, in read_command
return handle_errors(returncode, stdout, args, kwargs)
7.0.1RC1\etc\python\grass\script\core.py", line 312, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['r.info', '-gre',
u'map=Feb2014_111_112_753mos@PERMANENT\r'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.''
I have been trying to work with this module for a week and I cannot figure
out why it doesn’t work.
Many thanks in advance for any help.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2699>
