#2699: g.gui.iclass doesn't run after selecting training areas
Reporter: ThayseNery | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.0
Component: wxGUI | Version: 7.0.0
Resolution: | Keywords: g.gui.iclass, digitizer
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:13 hellik]:
> Replying to [comment:12 hellik]:
> > most works ok, beside import of vector training areas fails with (as
reported above):
> also there are no scatterplots displayed.
some further error messages:
Command 'd.rast --quiet map=mycomp@testiclass' failed
Details: Neither MONITOR (managed by d.mon command) nor
GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
Exception in thread Thread-25:
File "C:\Program Files\GRASS GIS
7.0.5\Python27\lib\threading.py", line 808, in
__bootstrap_inner
self.run()
7.0.5\gui\wxpython\core\gthread.py", line 94, in run
ret = vars()['callable'](*args, **kwds)
7.0.5\gui\wxpython\iscatt\iscatt_core.py", line 256, in
EditedFeature
self._updateCatRast(bboxs[i], areas_cats[i],
updated_cats)
7.0.5\gui\wxpython\iscatt\iscatt_core.py", line 281, in
_updateCatRast
self._rasterize(grass_region, layer, cat, patch_rast)
7.0.5\gui\wxpython\iscatt\iscatt_core.py", line 324, in
_rasterize
env = environs)
7.0.5\gui\wxpython\core\gcmd.py", line 675, in RunCommand
ps = grass.start_command(prog, flags, overwrite, quiet,
verbose, **kwargs)
7.0.5\etc\python\grass\script\core.py", line 362, in
start_command
return Popen(args, **popts)
7.0.5\etc\python\grass\script\core.py", line 65, in __init__
subprocess.Popen.__init__(self, args, **kwargs)
7.0.5\Python27\lib\subprocess.py", line 711, in __init__
errread, errwrite)
7.0.5\Python27\lib\subprocess.py", line 948, in
_execute_child
startupinfo)
TypeError: environment can only contain strings
Command 'd.rast --quiet map=class_1_1188.0' failed
Command 'd.rast --quiet map=class_2_1188.1' failed
C:\Program Files\GRASS GIS 7.0.5\Python27\lib\site-
packages\wx-2.8-msw-unicode\wx\lib\plot.py:1164:
FutureWarning: comparison to `None` will result in an
elementwise object comparison in the future.
if xAxis == None or yAxis == None:
Ticket URL: <https://trac.osgeo.org/grass/ticket/2699#comment:14>
