#270: autorendering interferes with layer selection
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
0. Enable auto-rendering.
1. Add at min. 2 layers.
2. Toggle off the 1st one, then the other, then again toggle the 1st one
on, and so on - note that both happen to be "selected, "highlited",
although only one can really be.
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by msieczka):
Replying to [comment:1 martinl]:
> Sorry I don't understand where you see a bug...
Well, if you repeat steps 1-2 with autorendering disabled and enabled, you
should notice that with autorendering enabled more than 1 layer happens to
be selected - distinguished in darker color. Of course only one can
*really* be selected. More than 1 layer looking like selected is a defect.
Better use 3 or 4 layers to see the issue clearly.
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cmbarton):
* status: new => closed
* resolution: => fixed
Comment:
I think this is fixed--probably in layer code rewrite of late summer. I've
tested it and there is no problem with highlighting or toggling the
display on/off checkbox. No ghost selection/highlight. I'm changing this
to resolved. But please test further if needed.
