#2703: 'ascii' codec can't decode byte 0xf6 in position 12: ordinal not in
range(128)
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.1
Component: Default | Version: svn-releasebranch70
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
refering to http://lists.osgeo.org/pipermail/grass-
dev/2015-July/075646.html
now tested with
GRASS Version: 7.1.svn
GRASS SVN revision: 65537
Build date: 2015-07-03
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
example 1 - v.to.db
choose layer from vector drop down menue:
File "C:\OSGEO4~2\apps\grass\grass-7.1.svn\gui\wxpython\gu
i_core\forms.py", line 2221, in OnSetValue
self.OnUpdateValues(event)
i_core\forms.py", line 628, in updateValuesHook
self.SetStatusText('
'.join(self.notebookpanel.createCmd(ignoreErrors = True)))
UnicodeDecodeError
'ascii' codec can't decode byte 0xf6 in position 11: ordinal
not in range(128)
- choose option e.g. coor from drop down menue:
UnicodeDecodeError
not in range(128)
UnicodeDecodeError
range(128)
=> no entry in the drop down menue for choosing columns
example 2 - v.patch
UnicodeDecodeError
not in range(128)
example 3 - r.param.scale
choosing layer from raster drop down menue:
UnicodeDecodeError
not in range(128)
example 4 - invoking v.db.addcolumn
i_core\forms.py", line 2056, in OnUpdateDialog
self.parent.updateValuesHook()
UnicodeDecodeError
not in range(128)
otherwise choosing layer from drop down menue works for e.g.
d.vect
g.copy
g.remove
all works if I change locale to english
Ticket URL: <https://trac.osgeo.org/grass/ticket/2703>
