#2709: pyGRASS Module runs twice from interactive Python prompt
Reporter: martinl | Owner:
Type: defect | Status: new
Priority: major | Milestone: 7.0.4
Component: PyGRASS | Version: unspecified
Resolution: | Keywords: interactive prompt
CPU: Unspecified | Platform: Linux
Comment (by zarch):
Hi Markus,
Replying to [comment:6 neteler]:
> GRASS 7.1.svn (eu_laea):~ > python
> Python 2.7.10 (default, Sep 8 2015, 17:20:17)
> [GCC 5.1.1 20150618 (Red Hat 5.1.1-4)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> >>> from grass.pygrass.modules import Module
> >>> Module('g.extension', flags='a')
> List of installed extensions (modules):
> r.skyview
> i.segment.hierarchical
> Module('g.extension') <<== ???
This is right, things are clearer using ipython:
In [1]: from grass.pygrass.modules import Module
In [2]: Module('g.extension', flags='a')
No extension (module) installed
Out[2]: Module('g.extension')
the python shell does not differentiate between print in stdout/stderr
(generate by the execution of module) and the representation of the
object.
The line Out[2] is returning the instance of the Module class.
If you are bothering by this just save the instance into a variable:
In [3]: gext = Module('g.extension', flags='a')
> Anyway, now entering the next command from the original report:
> >>> Module('r.mask', flags='r')
> ERROR: No existing MASK to remove
> [cut]
> msg = _("Module run %s %s ended with error") % (module, code)
> File "/home/neteler/software/grass71/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 583, in
__call__
> return self.run()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 706, in
run
> stdout, stderr = self.popen.communicate(input=self.stdin)
> File "/usr/lib64/python2.7/subprocess.py", line 796, in communicate
> self.wait()
> File "/usr/lib64/python2.7/subprocess.py", line 1384, in wait
> pid, sts = _eintr_retry_call(os.waitpid, self.pid, 0)
> File "/usr/lib64/python2.7/subprocess.py", line 476, in
_eintr_retry_call
> return func(*args)
> KeyboardInterrupt
Ipython does not soffer by this strange behavior and it works well.
In [4]: Module('r.mask', flags='r')
CalledModuleError Traceback (most recent call
last)
<ipython-input-4-217f55a3bd88> in <module>()
----> 1 rmsk = Module('r.mask', flags='r')
/home/pietro/docdat/src/gis/grass71/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/modules/interface/module.pyc in
__init__(self, cmd, *args, **kargs)
524
525 if args or kargs:
--> 526 self.__call__(*args, **kargs)
527 self.__call__.__func__.__doc__ = self.__doc__
528
__call__(self, *args, **kargs)
581 if self.check_:
582 self.check()
--> 583 return self.run()
584 return self
585
gnu/etc/python/grass/pygrass/modules/interface/module.pyc in run(self)
711 raise
CalledModuleError(returncode=self.popen.returncode,
712 code=self.get_bash(),
--> 713 module=self.name,
errors=stderr)
714 return self
715
CalledModuleError: Module run r.mask r.mask maskcats=* layer=1 -r ended
with error
Process ended with non-zero return code 1. See errors in the (error)
output.
No idea on why is not working properly in the standard python shell.
Just for the record it is working under python3...
Python 3.5.1 (default, Dec 7 2015, 12:58:09)
[GCC 5.2.0] on linux
File "<stdin>", line 1, in <module>
File "/home/pietro/docdat/src/gis/grass71/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 526, in
__init__
__call__
return self.run()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 713, in
run
module=self.name, errors=stderr)
grass.exceptions.CalledModuleError: Module run r.mask r.mask maskcats=*
layer=1 -r ended with error
output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2709#comment:7>
