[GRASS-dev] [GRASS GIS] #2711: v.patch -e crashes
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: svn-releasebranch70
Keywords: v.patch, wingrass | CPU: x86-32
Platform: MSWindows Vista |
v.patch -e --verbose input=geology@PERMANENT,streams@PERMANENT
output=testvpatchwithattributes
D1/3: G_set_program_name(): v.patch
D2/3: G_file_name(): path =
J:\gisdata/nc_spm_08_grass7/user1
D2/3: G_file_name(): path = J:\gisdata/nc_spm_08_grass7/user
1/vector/testvpatchwithattributes
D1/3: G_find_vector2(): name=geology@PERMANENT mapset=
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology
D1/3: Vect__open_old(): name = geology@PERMANENT, mapset = ,
layer = NULL, update = 0, head_only = 1, is_tmp = 0
D1/3: Vect__open_old(): is_tmp = 0 (check
GRASS_VECTOR_TEMPORARY)
D1/3: Vect_set_thresh(): thresh = 0.000000
D3/3: dig_init_plus()
D1/3: dig_spidx_init(), 2 dims
D3/3: dig_cidx_init()
D1/3: G_find_vector2(): name=geology mapset=PERMANENT
D1/3: Map: name = geology, mapset = PERMANENT, temporary = 0
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/frmt
D1/3: Vector format: 0 (native)
D1/3: Vect__read_head(): vector = geology@PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/head
D2/3: file open: read (mode = r)
J:\gisdata/nc_spm_08_grass7/user1/WIND
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228500
D3/3: region item: south: 215000
D3/3: region item: east: 645000
D3/3: region item: west: 630000
D3/3: region item: cols: 1500
D3/3: region item: rows: 1350
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: top: 1.000000000000000
D3/3: region item: bottom: 0.000000000000000
D3/3: region item: cols3: 1500
D3/3: region item: rows3: 1350
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D3/3: region item: t-b resol: 1
D1/3: Level request = 2
D1/3: Vect_open_topo(): name = geology mapset = PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/topo
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/coor
D1/3: get coor info:
D1/3: Vect_coor_info(): Info->size = 9016555, Info->mtime =
1198044380
D2/3: Topo header: file version 5.1 , supported from GRASS
version 5.1
D2/3: byte order 0
D2/3: header size 142
D2/3: topo off_t size = 4
D2/3: with_z 0
D2/3: coor size 9016555
D1/3: Topo head: coor size = 9016555, coor mtime = 0
D1/3: dig_load_plus()
D2/3: dig_free_plus()
D2/3: dig_free_plus_nodes()
D2/3: dig_free_plus_lines()
D2/3: dig_free_plus_areas()
D2/3: dig_free_plus_isles()
D2/3: dig_cidx_free()
version 5.1
D2/3: byte order 0
D2/3: with_z 0
D1/3: Vect_open_sidx(): name = geology mapset= PERMANENT
mode = old
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/sidx
1198044380
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.0
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.1
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.2
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.3
D2/3: Spidx header: file version 5.1 , supported from GRASS
version 5.1
D2/3: byte order 0
D2/3: header size 113
D2/3: with_z 0
D1/3: Sidx head: coor size = 9016555, coor mtime = 0
D2/3: Vect_cidx_open(): name = geology mapset= PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/cidx
D3/3: dig_read_cidx()
D3/3: Cidx header: file version 5.0 , supported from GRASS
version 5.0
D3/3: byte order 0
D3/3: header size 9
D1/3: Vect__open_old(): vector opened on level 2
D1/3: Vect_read_dblinks(): map = geology, mapset = PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/dbln
D1/3: dbln: 1/geology|geology|cat|$GISDBASE/$LOCATION_NAME/$
MAPSET/sqlite/sqlite.db|sqlite
D3/3: Field number <1>, name <geology>
D3/3: Vect_check_dblink: field 1, name geology
D1/3: field = 1 name = geology, table = geology, key = cat,
database =
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db, driver =
sqlite
D1/3: Dblinks read
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/geology/hist
D1/3: Vect_close(): name = geology, mapset = PERMANENT,
format = 0, level = 2, is_tmp = 0
D1/3: spatial index file closed
D1/3: close history file
D1/3: G_find_vector2(): name=streams@PERMANENT mapset=
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams
D1/3: Vect__open_old(): name = streams@PERMANENT, mapset = ,
D1/3: G_find_vector2(): name=streams mapset=PERMANENT
D1/3: Map: name = streams, mapset = PERMANENT, temporary = 0
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/frmt
D1/3: Vect__read_head(): vector = streams@PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/head
D1/3: Vect_open_topo(): name = streams mapset = PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/topo
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/coor
D1/3: Vect_coor_info(): Info->size = 2747992, Info->mtime =
1198044376
version 5.1
D2/3: byte order 0
D2/3: with_z 0
D2/3: coor size 2747992
D1/3: Topo head: coor size = 2747992, coor mtime = 0
version 5.1
D2/3: byte order 0
D2/3: with_z 0
D1/3: Vect_open_sidx(): name = streams mapset= PERMANENT
mode = old
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/sidx
1198044376
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.4
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.5
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.6
J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/6992.7
version 5.1
D2/3: byte order 0
D2/3: with_z 0
D1/3: Sidx head: coor size = 2747992, coor mtime = 0
D2/3: Vect_cidx_open(): name = streams mapset= PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/cidx
version 5.0
D3/3: byte order 0
D3/3: header size 9
D1/3: Vect_read_dblinks(): map = streams, mapset = PERMANENT
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/dbln
D1/3: dbln: 1/streams|streams|cat|$GISDBASE/$LOCATION_NAME/$
D3/3: Field number <1>, name <streams>
D3/3: Vect_check_dblink: field 1, name streams
D1/3: field = 1 name = streams, table = streams, key = cat,
database =
sqlite
D1/3: Dblinks read
J:\gisdata/nc_spm_08_grass7/PERMANENT/vector/streams/hist
D1/3: Vect_close(): name = streams, mapset = PERMANENT,
D1/3: Level request = 1
D1/3: Vect__open_old(): vector opened on level 1
database =
sqlite
D1/3: Dblinks read
D1/3: Vect_get_field(): field = 1
D1/3: Vect_get_dblink(): link = 0
D3/3: Vect_subst_var(): in =
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db, map =
D3/3: ->
J:\gisdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db
D3/3: db_start_driver_open_database(): drvname='sqlite', dbn
ame='J:\gisdata\nc_spm_08_grass7\PERMANENT\sqlite\sqlite.db'
D2/3: dbDbmscap(): opendir [C:\Program Files\GRASS GIS
7.0.1svn\driver\db\]
D3/3: win_spawn: args = C:\Windows\system32\cmd.exe /c
""C:\Program Files\GRASS GIS 7.0.1svn\driver\db\sqlite.exe""
D1/3: db_d_init_error(): SQLite
D3/3:
db_driver_open_database()
D3/3: name =
D2/3: name2 =
D2/3: path to db is
D3/3: describe_table()
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: nkcols = 8
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: col: cat, nkcols 0, litetype : 1, sqltype 3
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: onemap_pro, nkcols 1, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: PERIMETER, nkcols 2, litetype : 2, sqltype 6
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: col: GEOL250_, nkcols 3, litetype : 1, sqltype 3
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: col: GEOL250_ID, nkcols 4, litetype : 1, sqltype 3
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: GEO_NAME, nkcols 5, litetype : 3, sqltype 1
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: SHAPE_area, nkcols 6, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: SHAPE_len, nkcols 7, litetype : 2, sqltype 6
D3/3: db_close_database()
D2/3: db_close_database() result: 0 (0 means success)
format = 0, level = 1, is_tmp = 0
database =
sqlite
D1/3: Dblinks read
D3/3: ->
D3/3:
D3/3: name =
D2/3: name2 =
D2/3: path to db is
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: nkcols = 14
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: FNODE_, nkcols 1, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: TNODE_, nkcols 2, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: LPOLY_, nkcols 3, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: RPOLY_, nkcols 4, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: LENGTH, nkcols 5, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: FULL_HYDRO, nkcols 6, litetype : 2, sqltype 6
D3/3: sqltype = 6
D3/3: litetype = 2
D3/3: col: FULL_HYD_1, nkcols 7, litetype : 2, sqltype 6
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: FTYPE, nkcols 8, litetype : 3, sqltype 1
D3/3: sqltype = 3
D3/3: litetype = 1
D3/3: col: FCODE, nkcols 9, litetype : 1, sqltype 3
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: NAME, nkcols 10, litetype : 3, sqltype 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: RCH_CODE, nkcols 11, litetype : 3, sqltype 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: I_vs_P, nkcols 12, litetype : 3, sqltype 1
D3/3: sqltype = 1
D3/3: litetype = 3
D3/3: col: USGSstrm, nkcols 13, litetype : 3, sqltype 1
(Sat Jul 18 20:19:26 2015) Befehl ausgeführt (1 Min 7 Sek)
tested with
System Info
GRASS Version: 7.0.1svn
GRASS SVN Revision: 65608
Erstellungsdatum: 2015-07-18
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2711&gt;
Resolution: | Keywords: v.patch, wingrass
       CPU: x86-32 | Platform: MSWindows Vista
Comment (by martinl):
Segfault should be fixed in r65741. Please could you test it in trunk?
BTW, the command doesn't work for me
ERROR: Number of columns differ
Ticket URL: <https://trac.osgeo.org/grass/ticket/2711#comment:1&gt;
