GDAL
July 19, 2015, 1:18pm
1
#2712: WARNING: Unable to rename null file
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: svn-releasebranch70
Keywords: | CPU: x86-32
Platform: MSWindows Vista |
running some raster modules, I get following warning message:
e.g.
(Sun Jul 19 15:14:36 2015)
r.slope.aspect --verbose elevation=elevation@PERMANENT slope=myslope
Prozent fertig...
Höhen-Ergebnisse für Mapset <user1> in <nc_spm_08_grass7>.
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/4828.1' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/myslope/null': Permission
denied
minimale berechnete Hangneigung 0.0000, maximale berechnete Hangneigung
38.6894.
Neigungs-Rasterkarte <myslope> komplett.
(Sun Jul 19 15:14:38 2015) Befehl ausgeführt (1 Sek)
(Sun Jul 19 15:15:24 2015)
r.param.scale --verbose input=elevation@PERMANENT output=mymorpho
method=feature
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/3040.1' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/mymorpho/null': Permission
denied
(Sun Jul 19 15:15:26 2015) Befehl ausgeführt (1 Sek)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
July 19, 2015, 1:20pm
2
Resolution: | Keywords: raster
CPU: x86-32 | Platform: MSWindows Vista
Changes (by hellik):
* keywords: => raster
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:1> ;
GDAL
July 19, 2015, 1:21pm
3
Comment (by hellik):
Replying to [ticket:2712 hellik]:
e.g. also in r.watershed
(Sun Jul 19 15:20:04 2015)
r.watershed --verbose elevation=elevation@PERMANENT threshold=100
accumulation=myaccum tci=mytopoi drainage=mydraindir basin=myabasin
ABSCHNITT 1a (von 5): Initiiere den Speicher.
ABSCHNITT 1b (of 5): Ermittle den Fluß aus der Karte heraus.
SECTION 2: A* Search.
SECTION 3a: Accumulating Surface Flow with MFD.
SECTION 3b: Adjusting drainage directions.
ABSCHNITT 4: Bestimme Wassereinzugsgebiet.
ABSCHNITT 5: Schließe Karten.
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/4520.1' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/myabasin/null': Permission
denied
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/4520.3' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/myaccum/null': Permission
denied
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/4520.5' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/mytopoi/null': Permission
denied
'J:\gisdata/nc_spm_08_grass7/user1/.tmp/unknown/4520.7' to
'J:\gisdata/nc_spm_08_grass7/user1/cell_misc/mydraindir/null': Permission
denied
(Sun Jul 19 15:20:14 2015) Befehl ausgeführt (9 Sek)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:2> ;
GDAL
July 19, 2015, 1:27pm
4
Replying to [comment:2 hellik]:
see also https://trac.osgeo.org/grass/ticket/2689
in contrary to #2689 , the null file isn't there.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:3> ;
GDAL
July 19, 2015, 1:28pm
5
Priority: blocker | Milestone: 7.0.1
Changes (by neteler):
* priority: normal => blocker
Comment:
The file in question is
lib/raster/close.c
denied
The directory separators are likely wrong. Since it is in libraster it
affects several modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:4> ;
GDAL
July 19, 2015, 1:29pm
6
Replying to [comment:3 hellik]:
and also here: https://trac.osgeo.org/grass/ticket/2434
Ticket URL: <http://trac.osgeo.org/grass/ticket/2712#comment:5> ;
GDAL
July 19, 2015, 1:30pm
7
tested with the elevation data of the nc sample data set
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:6> ;
GDAL
July 19, 2015, 6:21pm
8
Component: LibRaster | Version: svn-trunk
Changes (by annakrat):
* version: svn-releasebranch70 => svn-trunk
* component: Default => LibRaster
* milestone: 7.0.1 =>
Comment:
Replying to [comment:6 hellik]:
Problem seems to be only in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:7> ;
GDAL
July 19, 2015, 6:41pm
9
Priority: blocker | Milestone: 7.1.0
Changes (by martinl):
* milestone: => 7.1.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:8> ;
GDAL
July 21, 2015, 6:13pm
10
Comment (by martinl):
The bug seems to be related to the recent changes in null data support
done in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:9> ;
GDAL
July 23, 2015, 12:02pm
11
Comment (by glynn):
Replying to [comment:9 martinl]:
done in trunk.
I think that it's because r65323 deferred closing the null file (because a
compressed null file needs to have the row pointers written out), meaning
that the file is still open at the time of the rename() call. This is
valid on Unix but not on Windows (although the MSDN documentation neglects
to mention this in the description of the EACCESS error for rename()).
So, the order needs to be:
* Write out row pointers
* Close file
* Rename file
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:10> ;
GDAL
July 23, 2015, 12:09pm
12
Comment (by glynn):
Replying to [comment:10 glynn]:
> * Close file
> * Rename file
Try r65775.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:11> ;
GDAL
July 26, 2015, 8:17am
13
Replying to [comment:11 glynn]:
> > * Close file
> > * Rename file
> Try r65775.
tested with
GRASS Version: 7.1.svn
GRASS SVN revision: 65777
Build date: 2015-07-25
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
Prozent fertig...
38.6894.
(Sun Jul 26 10:12:35 2015) Befehl ausgeführt (2 Sek)
r.param.scale --verbose input=elevation@PERMANENT output=myfeature
method=feature
(Sun Jul 26 10:14:01 2015) Befehl ausgeführt (1 Sek)
(Sun Jul 26 10:15:31 2015) Befehl ausgeführt (7 Sek)
seems to be fixed now, closing ticket
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:12> ;
GDAL
July 26, 2015, 8:18am
14
Type: defect | Status: closed
Resolution: fixed | Keywords: raster
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:13> ;
GDAL
July 26, 2015, 8:37am
15
> > * Close file
> > * Rename file
> Try r65775.
#2689 seems to be solved, #2434 is still valid
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:14> ;
GDAL
July 27, 2015, 8:38pm
16
Comment (by glynn):
Replying to [comment:14 hellik]:
#2434 was opened long before any of these changes were made.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:15> ;
GDAL
July 28, 2015, 9:32am
17
Replying to [comment:15 glynn]:
right; but there seems to be similar problems with raster:
see e.g. 2434#comment:14
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.1' to
'J:\gisdata\nc_spm_08_grass7\user1\cell_misc\elev_lid792_rast\null':
Permission denied
WARNING: Unable to rename cell file
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.0' to
'J:\gisdata\nc_spm_08_grass7\user1\fcell\elev_lid792_rast': Permission
denied
WARNING: Unable to write quant rules: raster map <elev_lid792_rast> is
integer
Ticket URL: <https://trac.osgeo.org/grass/ticket/2712#comment:16> ;
