[GRASS-dev] [GRASS GIS] #2726: v.unpack fails when importing into a cartesian CRS
Reporter: micha | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Default | Version: 7.0.1
Keywords: | CPU: Unspecified
Platform: Linux |
WHen using v.pack/v.unpack to move vector maps to a different machine, and
the LOCATION is a cartesian, unprojected, X-Y coordinate system , the
operation fails with:
GRASS 7.0.1 (XY):~ > v.unpack ~/Desktop/Allkavels.pack
   File "/usr/lib/grass70/scripts/v.unpack", line 211, in <module>
     sys.exit(main())
   File "/usr/lib/grass70/scripts/v.unpack", line 114, in main
     filename_b=loc_proj, proj=True):
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 895, in
compare_key_value_text_files
     checkunits=units)
   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 822, in
_text_to_key_value_dict
     text = open(filename, "r").readlines()
IOError: [Errno 2] No such file or directory:
'/home/micha/GIS/grass/XY/test/.tmp/work-vm/23766.0/PROJ_INFO'
The PROJ_INFO file ideed does not exist in an unprojected LOCATION.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2726&gt;
Resolution: | Keywords: v.pack, v.unpack
       CPU: Unspecified | Platform: Linux
Changes (by martinl):
* keywords: => v.pack, v.unpack
Ticket URL: <https://trac.osgeo.org/grass/ticket/2726#comment:1&gt;
Comment (by annakrat):
I fixed it yesterday in r66019, not yet backported, please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2726#comment:2&gt;
I backported it in r66358, however I don't know if anyone else tested it.
If yes, please close it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2726#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.pack, v.unpack
Changes (by neteler):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.3 => 7.0.2
Comment:
No response, closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2726#comment:5&gt;
