#2728: g.gui.animation (wx3): TypeError : in method 'new_SpinCtrl', expected
argument 9 of type 'int'
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.animate | CPU: Unspecified
Platform: Unspecified |
Using freshly checked out trunk, and trying to enter the settings dialog
of g.gui.animation, I get:
Settings: unable to get value 'animation:nprocs:value'
File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
-unknown-linux-gnu/gui/wxpython/animation/frame.py", line
297, in OnPreferences
dlg = PreferencesDialog(parent=self, giface=self._giface)
File
-unknown-linux-gnu/gui/wxpython/animation/dialogs.py", line
1479, in __init__
self._createGeneralPage(self.notebook)
File
1516, in _createGeneralPage
initial=UserSettings.Get(group='animation', key='nprocs',
subkey='value'))
File "/usr/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/_controls.py", line 2344, in
__init__
_controls_.SpinCtrl_swiginit(self,_controls_.new_SpinCtrl(*a
rgs, **kwargs))
TypeError
in method 'new_SpinCtrl', expected argument 9 of type 'int'
Resolution: | Keywords: g.gui.animate
Comment (by annakrat):
Not sure what's happening there, I can't reproduce... In the settings file
(called wx) in your home folder, do you have a line starting with
`animation;nprocs;value`? Most probably not, but that shouldn't be a
problem. Could you run in any python console:
from multiprocessing import cpu_count
cpu_count()
that should give you an integer. Ideally, you could look what is actually
passed to the SpinCtrl constructor - should be integer, but apparently
it's not.
