[GRASS-dev] [GRASS GIS] #274: vdigit: cursor and vertex are apart when moving vertices
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
develbranch6 r33238
Simple example:
1. Digitize a single line with 2 nodes.
2. Choose "Move vertex" tool.
3. Hover over a node, select it with the left button and, before 0.5 a
second passes, move mouse very quickly.
The vertex and cursor become apart (the distance between them depend on
how promptly and quickly you moved the mouse). Pressing the right button
to confirm the placement, behaves like if the middle button was pressed
actually - the edit is cancelled.
Weird. Looks like if vdigit needs few tens of a second brake between
activating the tool and using it. Fixable?
Ticket URL: <http://trac.osgeo.org/grass/ticket/274&gt;
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by msieczka):
  * component: default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:1&gt;
Comment (by msieczka):
Martin
This is quite a bug. On Thursday next week I have live-presentation of
GRASS at a surveyors' conference in Poland [1]. Do you think there's a
chance the issue will be solved until then? I'd love to show them the new
digitizer...
[1]http://www.wodgik.katowice.pl/konferencja/2008/index.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:2&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Should be fixed in r33291.
  Choose vertex -- left mouse button
  Keep button pressed
  Move mouse pointer
  Release left button
  Move mouse pointer
  Right mouse button -> vertex moved to the right position
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:3&gt;
Replying to [comment:3 martinl]:
Sort of better but still problems.
> Keep button pressed
> Move mouse pointer
> Release left button
> Move mouse pointer
If I do it exactly this way, the cursor and edited vertex are almost
*always* apart. See the screencast at
http://www.sieczka.org/tmp/out_noloop.html for an exmaple.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:4&gt;
Comment (by martinl):
Replying to [comment:4 msieczka]:
I don't see this behaviour as a bug. Try to confirm action, vertex is
moved properly. Standard use
  * left down to select feature or vertex
  * left up
  * move pointer
  * right up to confirm
or use 'apart'
  * move pointer
  * left up
  * move
  * confirm
M.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:5&gt;
Replying to [comment:5 martinl]:
> * left up
> * move pointer
> or use 'apart'
> * move pointer
> * left up
> * move
> * confirm
Such an "apart mode" should not be possible IMO. What would be the use for
it? It only confuses the user.
Could GUI take care of that so that both use ways would work the same?
And still, even with the "standard use mode", if one moves mouse cursor
right after selecting a vertex, there is a high likelihood the vertex and
cursor become apart. This defect will bring troubles to folks with a fast
hand. Digitizers in commercial setups will not be attracted to GRASS for
that.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:6&gt;
  Priority: major | Milestone: 6.4.0
  * priority: critical => major
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Comment:
Should be already fixed in releasebranch_64/develbranch_6/trunk. Reopen
ticket if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:8&gt;
      Type: defect | Status: reopened
  * status: closed => reopened
  * resolution: fixed =>
Comment:
It's not fixed. After moving the very first vertex digitizer crashes:
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 1125, in MouseActions
self.OnMouseMoving(event)
pdisp.py", line 2009, in OnMouseMoving
if len(self.vdigitMove['id']) > 0:
TypeError
tuple indices must be integers
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
TypeError
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:9&gt;
Oh, there seem to be some related fixes in r35033. Checking the out now...
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:10&gt;
  * status: reopened => closed
Comment:
So it is fixed. Cool.
Ticket URL: <http://trac.osgeo.org/grass/ticket/274#comment:11&gt;
