GDAL
September 11, 2015, 4:34pm
1
#2740: v.in.ogr: wrong projection check when importing geometry column from table
with multiple geometry columns
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Vector | Version: svn-trunk
Keywords: v.in.ogr geometry columns | CPU: Unspecified
Platform: Unspecified |
r63604 introduced the possibility to import from data sources with
multiple geometry columns (gdal RFC41).
However, AFAIU, the projection check has not been changed and so the
projection is gotten from the layer, not the field (aka geometry column).
It seems to me that the gathering of information concerning the geometry
column in
[http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.ogr/main.c#L870
lines 870ff of main.c] needs to be moved higher up to before getting the
projection
([http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.in.ogr/main.c#L543
lines 543ff]), so that the projection can be gotten from the '''geometry
column''' and not from the layer.
But I'm not 100% sure of understanding the code correctly, so this needs
confirmation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2740> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
September 12, 2015, 10:13pm
2
Reporter: mlennert | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords: v.in.ogr geometry columns
Changes (by martinl):
* owner: grass-dev@… => martinl
* cc: grass-dev@… (added)
* status: new => assigned
Comment:
Please try out r66184. After some testing could be backport to relbr70.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2740#comment:1> ;
GDAL
September 13, 2015, 11:02am
3
Comment (by mlennert):
Replying to [comment:1 martinl]:
Works nicely for my case.
Thanks !
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2740#comment:2> ;
GDAL
September 13, 2015, 12:25pm
4
Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.ogr geometry columns
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:2 mlennert]:
relbr70.
perfect, backported in r66187. Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2740#comment:3> ;
