GDAL
September 16, 2015, 10:28am
1
#2743: v.net.steiner core dump
Reporter: clara | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.0
Keywords: | CPU: x86-64
Platform: Linux |
the command core dumped. I tried with my data and then I followed the
example based on the Spearfish dataset proposed in the manual page
The error in both cases is
>WARNING: dglShortestPath error: Head Node Not Found
Segmentation fault (core dumped)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2743> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
September 25, 2015, 12:33pm
2
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by gfleming):
affects me too
Ticket URL: <https://trac.osgeo.org/grass/ticket/2743#comment:1> ;
GDAL
March 5, 2016, 8:43am
3
Type: defect | Status: closed
Priority: normal | Milestone: 7.1.0
Component: Vector | Version: 7.0.0
Resolution: fixed | Keywords:
CPU: x86-64 | Platform: Unspecified
Changes (by marisn):
* status: new => closed
* platform: Linux => Unspecified
* component: Default => Vector
* resolution: => fixed
* milestone: => 7.1.0
Comment:
I believe that I fixed this issue with r68000 for 7.1
Test & reopen if it isn't so.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2743#comment:2> ;
GDAL
March 5, 2016, 10:21am
4
Comment (by marisn):
Backported to 7.0 (7.0.4) in r68004 as the issue was present in 7.0.
6.4 is not affected and now output of 7.x is identical to 6.4 one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2743#comment:3> ;
GDAL
September 29, 2016, 7:13am
5
Priority: normal | Milestone: 7.2.0
Comment (by mlennert):
Can this be closed ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2743#comment:5> ;
GDAL
September 29, 2016, 9:54am
6
Replying to [comment:5 mlennert]:
It is already closed as it was fixed for 7.0.x and 7.2.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/2743#comment:6> ;
