[GRASS-dev] [GRASS GIS] #2744: r.import latlong bug
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: r.import | CPU: Unspecified
Platform: Unspecified |
Would it be possible to catch this user error?
The user tried to import reprojected METOP-A data (Stereographic
projection) into a LatLong location (yeah, things happen):
r.import input=EUMETSAT/output/Soil
moisture/1/ascat_METOPA.20090401163331.12715_soil_moisture.tif
output=01_third
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Proceeding with import of 1 raster bands...
Importing raster map <01_third>...
File "/usr/local/grass-7.1.svn/scripts/r.import", line
333, in <module>
sys.exit(main())
258, in main
srcregion = grass.parse_key_val(tgtextents,
val_type=float, vsep=' ')
File
"/usr/local/grass-7.1.svn/etc/python/grass/script/utils.py",
line 223, in parse_key_val
result[k] = val_type(v)
ValueError: invalid literal for float(): 53:39:06.894826N
Probably the Python code which compares the two projections (input file
and location) failed?
Solution: It could be taken from r.pack where a similar test is done.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744&gt;
  output=01_third
  333, in <module>
      sys.exit(main())
  258, in main
    File
No, IIUC, the problem seems to be that parse_key_val at line 258 expects boundary coordinates to be in float, but r.proj on delivers lat lon coordinates in a character string. Maybe you can try with just deleting the 'val_type=float' in the call parameters. I'm not sure this is absolutely necessary.
Moritz
Resolution: | Keywords: r.import
Comment (by mlennert):
Replying to [ticket:2744 neteler]:
why is this a user error ? r/v.import are supposed to allow importing data
that is in one projection into a location in another projection.
output=01_third
> 333, in <module>
> sys.exit(main())
> 258, in main
> File
As mentioned on the ML (sorry, I didn't notice this was a ticket, need
more sleep):
parse_key_val has an optional parameter val_type which is set to 'float',
here, but r.proj outputs lat-lon coordinates in DMS style. I don't know
why val_type is set here and if that is necessary as the results are just
sent to g.region which can take strings as input.
So as first try I would just delete this parameter from the parse_key_val
call and see what happens.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:1&gt;
Comment (by annakrat):
Replying to [comment:1 mlennert]:
parse_key_val call and see what happens.
Should be fixed in r66298, but please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:2&gt;
  Priority: normal | Milestone: 7.0.3
Changes (by annakrat):
* milestone: 7.1.0 => 7.0.3
Comment:
Needs testing and backport.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:3&gt;
Comment (by martinl):
Any to plan to backport? Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:4&gt;
Comment (by neteler):
I don't have any more the ASCAT dataset mentioned above for testing of
trunk. I vote for backporting, though, since no complaints came in 3 month
about the change in trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:5&gt;
Replying to [comment:5 neteler]:
trunk.
OK, now I got it sent to me. Trunk
GRASS 7.1.svn (latlong):~/Downloads > r.import
input=ascat_METOPA.20090401163331.12715_soil_moisture.tif output=01_third
  100%
Estimated target resolution for input band <01_third>: 0.120517219445
Reprojecting <01_third>...
WARNING: No data base element files found
GRASS 7.1.svn (latlong):~ > r.info -r 01_third
min=-1
max=74.3199996948242
It no longer crashes (note: the datum is also not recognized by GDAL; not
sure what the warning means).
And the resulting map looks ok.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:6&gt;
As this is a bug fix and it does not change the behaviour of the module
except for cases where the module would crash, I think this should
definitely be backported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.import
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:7 mlennert]:
> I think this should definitely be backported.
I just checked: nothing to backport since the module was introduced in
relbr70 only after the fix:
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_7_0/scripts/r.import
Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2744#comment:8&gt;
