#2746: GUI fails to start: wx3.0 issue ?
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.2
Component: wxGUI | Version: svn-releasebranch70
Keywords: g.gui wxgui | CPU: Unspecified
Platform: Linux |
With a freshly checked out grass70_release, I get the following error when
trying to launch the wxGUI:
ATTENTION : le chargement de certaines extensions à échoué. Merci de
mettre à jour vos extensions en lançant 'g.extension.all -f'.
File "/data/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-unknown-
linux-gnu/gui/wxpython/wxgui.py", line 142, in <module>
sys.exit(main())
linux-gnu/gui/wxpython/wxgui.py", line 134, in main
app = GMApp(workspaceFile)
linux-gnu/gui/wxpython/wxgui.py", line 49, in __init__
wx.App.__init__(self, False)
File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line
8628, in __init__
self._BootstrapApp()
8196, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
linux-gnu/gui/wxpython/wxgui.py", line 83, in OnInit
workspace = self.workspaceFile)
linux-gnu/gui/wxpython/lmgr/frame.py", line 132, in __init__
self._createMenuBar()
linux-gnu/gui/wxpython/lmgr/frame.py", line 252, in _createMenuBar
self.menubar = Menu(parent=self,
model=self._menuTreeBuilder.GetModel(separators=True))
linux-gnu/gui/wxpython/gui_core/menu.py", line 44, in __init__
self.Append(self._createMenu(child), child.label)
linux-gnu/gui/wxpython/gui_core/menu.py", line 52, in _createMenu
subMenu = self._createMenu(child)
linux-gnu/gui/wxpython/gui_core/menu.py", line 58, in _createMenu
self._createMenuItem(menu, label=child.label, **data)
linux-gnu/gui/wxpython/gui_core/menu.py", line 99, in _createMenuItem
rhandler = eval('self.parent.' + handler)
File "<string>", line 1, in <module>
AttributeError: 'GMFrame' object has no attribute 'OnTplotTool'
Error in atexit._run_exitfuncs:
File "/usr/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
PyAssertionError: C++ assertion "GetEventHandler() == this" failed at
../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event
handlers must have been removed
Error in sys.exitfunc:
wx._core.PyAssertionError: C++ assertion "GetEventHandler() == this"
failed at ../src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed
event handlers must have been removed
Build and library info:
./configure --prefix=/usr/lib --sysconfdir=/etc --sharedstatedir=/var
--enable-socket --enable-shared --enable-largefile --with-postgres --with-
mysql --with-pthread --with-cxx --with-x --with-gdal --with-freetype
--with-motif --with-readline --with-nls --with-odbc --with-sqlite --with-
freetype-includes=/usr/include/freetype2 --with-tcltk-
includes=/usr/include/tcl --with-postgres-includes=/usr/include/postgresql
--with-mysql-includes=/usr/include/mysql --with-proj-share=/usr/share/proj
--with-python=/usr/bin/python-config --with-cairo --with-geos --with-blas
--with-lapack --with-liblas=/usr/bin/liblas-config
libgis Revision: 64733
libgis Date: 2015-02-25 01:56:29 +0100 (mer 25 fév 2015)
PROJ.4: 4.9.1
GDAL/OGR: 1.11.2
GEOS: 3.5.0
SQLite: 3.8.11.1
wx: 3.0.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2746>
