#2765: added "_1" to attribute table's name when working with v.overlay
Reporter: lfurtkevicova | Owner: martinl
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.0
Component: Database | Version: 7.0.1
Resolution: fixed | Keywords: database, v.overlay
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:11 martinl]:
> Replying to [comment:10 mmetz]:
> > What are the results now with `v.overlay olayer=0,1,2` and with with
`v.overlay olayer=1,2,3`?
> What is the difference between `olayer=0,1,2`, or `olayer=1,2,3` and
`olayer=0,1,1`? The manuals just says "If of the olayer option is greater
than 0..."? All (`olayer=0,1,2`, `olayer=1,2,3` and `olayer=0,1,1`)
commands produce just one table linked (tested with 7.0.5svn), so the
MTABLE is not needed I would say. Is there any possibility that
`v.overlay` produces a map with more tables linked?
The intention of the olayer option is to produce a map with zero to 3
layers, optionally with attribute tables. There were two bugs in
v.overlay, preventing options like `olayer=0,1,2` or `olayer=1,2,3` to
produce a map with multiple layers (to be precise, categories in multiple
layers). Fixed in r69348-50 (trunk, relbr72, relbr70).
`olayer=1,0,0` should produce new unique categories i output layer 1.
`olayer=0,1,2` should copy categories from ainput, alayer to output layer
1 and copy categories from binput, blayer to output layer 2, unique new
categories are not created. `olayer=1,2,3` should create unique new
categories in output layer 1, copy categories from ainput, alayer to
output layer 2 and copy categories from binput, blayer to output layer 3.
`olayer=0,1,1` should copy categories from ainput, alayer to output layer
1 and not copy categories from binput, blayer because the output layer
numbers are identical.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2765#comment:12>
