#2770: r.mapcalc reports syntax error for valid script but no error for separate
expressions
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Keywords: r.mapcalc | CPU: Unspecified
Platform: Unspecified |
Seems that r.mapcalc doesn't like some sequences of valid expressions.
Following examples show the same expressions copy/pasted into interactive
r.mapcalc session all together and one by one. Notice - same syntax once
causes "syntax error" but no "syntax error" is generated if execution
happens to be performed on a separate r.mapcalc process.
r.mapcalc --overwrite
Enter expressions, "end" when done.
mapcalc> speed_up = if(speed < 5, speed + 1, speed)
mapcalc> max_speed = if( !isnull(speed[0,1]), 0,\
mapcalc> if( !isnull(speed[0,2]), 1,\
mapcalc> if( !isnull(speed[0,3]), 2,\
mapcalc> if( !isnull(speed[0,4]), 3,\
mapcalc> if( !isnull(speed[0,5]), 4, 5)))))
mapcalc> res_speed = if(speed_up > max_speed, max_speed, speed_up)
mapcalc> moved = if( res_speed[0, 0] == 0, 0,\
syntax error, unexpected '[', expecting ')'
mapcalc> if( res_speed[0,-1] == 1, 1,\
mapcalc> if( res_speed[0,-2] == 2, 2,\
mapcalc> if( res_speed[0,-3] == 3, 3,\
mapcalc> if( res_speed[0,-4] == 4, 4,\
mapcalc> if( res_speed[0,-5] == 5, 5, null()))))))
mapcalc> end
Parse error
mapcalc> end
100%
GRASS 7.1.svn (xy_loc):~/soft/grass_trunk > r.mapcalc --overwrite
mapcalc> end
100%
mapcalc> end
100%
mapcalc> end
100%
Ticket URL: <https://trac.osgeo.org/grass/ticket/2770>
