GDAL
October 20, 2015, 8:53pm
1
#2772: Installing addons for windows gives error that File is not zip file
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Default | Version: svn-releasebranch70
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
After installation of GRASS 7.0.2 rc1 attempted reinstall of v.lidar.mcc
gett ERROR that file is not a zip file.
g.extension extension=v.lidar.mcc svnurl=http://svn.osgeo.org/grass/grass-
addons/grass7
WARNING: Extension <v.lidar.mcc> already installed. Re-installing...
Downloading precompiled GRASS Addons <v.lidar.mcc>...
ERROR: File is not a zip file:
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.2RC1/v.lidar.mcc.zip
Ticket URL: <http://trac.osgeo.org/grass/ticket/2772> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
October 20, 2015, 9:00pm
2
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Description changed by martinl:
Old description:
/grass-addons/grass7
New description:
addons/grass7
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:1> ;
GDAL
October 20, 2015, 9:01pm
3
Reporter: dnewcomb | Owner: martinl
Type: defect | Status: assigned
Component: Addons | Version: svn-releasebranch70
Changes (by martinl):
* cc: grass-dev@… (added)
* status: new => assigned
* component: Default => Addons
* owner: grass-dev@… => martinl
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:2> ;
GDAL
October 20, 2015, 10:18pm
4
Comment (by martinl):
Should be fixed now (r66549 & r66550).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:3> ;
GDAL
5
Resolution: | Keywords: wingrass, addons
* keywords: => wingrass, addons
Ticket URL: <http://trac.osgeo.org/grass/ticket/2772#comment:4> ;
GDAL
October 21, 2015, 7:10pm
6
Should be fixed, closing. Please re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:5> ;
GDAL
October 21, 2015, 7:17pm
7
Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, addons
* status: assigned => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:6> ;
GDAL
November 4, 2015, 1:03pm
8
Type: defect | Status: reopened
Changes (by dnewcomb):
* status: closed => reopened
* resolution: fixed =>
Comment:
Downloaded extensions on Wingrass 7.0.2RC2-1.exe still not seen as
zipfiles
(Wed Nov 04 07:59:56 2015)
addons/grass7
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.2RC2/v.lidar.mcc.zip
(Wed Nov 04 07:59:58 2015) Command finished (2 sec)
(Wed Nov 04 08:02:07 2015)
g.extension extension=r.biodiversity svnurl=http://svn.osgeo.org/grass
Downloading precompiled GRASS Addons <r.biodiversity>...
http://wingrass.fsv.cvut.cz/grass70/addons/grass-7.0.2RC2/r.biodiversity.zip
(Wed Nov 04 08:02:09 2015) Command finished (1 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2772#comment:7> ;
GDAL
November 4, 2015, 2:22pm
9
Comment (by neteler):
The files are simply not there on that server:
The requested URL /grass70/addons/grass-7.0.2RC2/r.biodiversity.zip was
not found on this server.
Since RC2 winGRASS got published today, it probably takes a day to get the
addons build.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:8> ;
GDAL
November 4, 2015, 2:27pm
10
Extra comment:
g.extension should emit a message in case the file is not found on the
server (file size 0) since "ERROR: File is not a zip file" is misleading
here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:9> ;
GDAL
November 4, 2015, 3:36pm
11
* status: reopened => closed
Comment:
Replying to [comment:8 neteler]:
the addons build.
Should be fixed. Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2772#comment:10> ;
