[GRASS-dev] [GRASS GIS] #2773: grass-7.0.1 fails to build when compiled with -Werror=format-security"
Reporter: wraeth | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: 7.0.1
Keywords: | CPU: Unspecified
Platform: Linux |
Building of Grass 7.0.1 fails when the compiler options include -Werror
=format-security, indicating insecure handling of string formatting.
Compile log will be attached containing errors.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: Linux
Changes (by wraeth):
* Attachment "grass-7.0.1:201510212148.log.gz" added.
Compressed build output
Ticket URL: <http://trac.osgeo.org/grass/ticket/2773&gt;
  Priority: normal | Milestone: 7.0.1
Changes (by neteler):
* milestone: => 7.0.1
Comment:
This happens when configuring with --with-nls, is that true in your case?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:1&gt;
  Reporter: wraeth | Owner: martinl
      Type: defect | Status: assigned
  Priority: normal | Milestone: 7.0.2
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@… => martinl
* cc: grass-dev@… (added)
* milestone: 7.0.1 => 7.0.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:2&gt;
Comment (by martinl):
Should be fixed in r66561 (trunk). If no objection I would backport it to
relbr70 within few next days.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:3&gt;
Comment (by wraeth):
Replying to [comment:1 neteler]:
case?
Compiling with --without-nls produces the same results.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:3 martinl]:
to relbr70 within few next days.
Done in r66613. Closing the ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:5&gt;
Comment (by neteler):
Partially backported to relbranch64 in r66616
Ticket URL: <https://trac.osgeo.org/grass/ticket/2773#comment:6&gt;
