[GRASS-dev] [GRASS GIS] #2775: Hangs when closing db drivers
Reporter: rblazek | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Database | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Linux |
Module hangs if db drivers are not closed in revers order to the order in
which were opened. For example open driver A, open driver B, close driver
A hangs forever on waitpid() in G_wait() because driver process does not
exit when its stdin is closed in db_shutdown_driver() by
fclose(driver->send). fclose() returns 0 (ok). The driver is probably
hanging on db!__recv_procnum() even if stdin was closed.
It is fixed by enabling procedure DB_PROC_SHUTDOWN_DRIVER like it is used
on Window. Patch attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: Linux
Changes (by rblazek):
* Attachment "close-driver.patch" added.
Comment (by rblazek):
Annother fix suggested by Glynn and resolving the real problem also works
https://lists.osgeo.org/pipermail/grass-dev/2015-October/076925.html
         void close_on_exec(int fd)
         #ifndef __MINGW32__
             int flags = fcntl(fd, F_GETFD);
             fcntl(fd, F_SETFD, flags | FD_CLOEXEC);
         #endif
         close_on_exec(p1[READ]);
         close_on_exec(p1[WRITE]);
         close_on_exec(p2[READ]);
         close_on_exec(p2[WRITE]);
Patch attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:1&gt;
* Attachment "close-driver-2-glynn.patch" added.
Suggested by Glynn, FD_CLOEXEC
  Priority: normal | Milestone: 7.0.1
Changes (by neteler):
* milestone: => 7.0.1
Comment:
To apply the second patch? Also backport it?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:2&gt;
More from Glynn about the possibility to close all descriptors
https://lists.osgeo.org/pipermail/grass-dev/2015-October/077010.html
which does not seem to be optimal.
I think that both patches should be applied. The second is resolving the
real problem.
The first, explicitly sending close procedure to driver cannot harm and it
should also cover all cases when a descriptor is opened (even not db
related) without setting FD_CLOEXEC.
Backport would be useful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:3&gt;
  Priority: normal | Milestone: 7.0.3
Changes (by martinl):
* milestone: 7.0.1 => 7.0.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:4&gt;
  Priority: blocker | Milestone: 7.0.3
* priority: normal => blocker
Comment:
Likely relevant for the winGRASS (64bit), promoting to blocker since
patches are provided.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:5&gt;
Comment (by martinl):
I took liberty to apply both patches in trunk (r67290). Testing highly
welcomed before we do backport to relbr70 (must be done before 7.0.3RC1)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:6&gt;
Comment (by mlennert):
Replying to [comment:6 martinl]:
Any ideas of how to test this specifically ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:7&gt;
Replying to [comment:7 mlennert]:
svn cat https://svn.osgeo.org/grass/sandbox/martinl/test-2775.c >
test-2775.c
gcc test-2775.c -I/path/to/grassheaders -lgrass_dbmiclient
-L/path/to/grasslibs
./a.out
will hang when closing `db1`
closing db1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:8&gt;
After testing I took liberty to backport changes also to relbr70 - r67369.
Now the sample program finishes successfully also here.
closing db1
closing db2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: new => closed
* resolution: => fixed
Comment:
Closing the ticket, feel free to re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2775#comment:10&gt;
