#2778: v.rast.stats: ERROR: Input window changed while maps are open for read.
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: v.rast.stats | CPU: x86-32
Platform: MSWindows 7 |
taken from the mailing list [http://lists.osgeo.org/pipermail/grass-
dev/2015-October/076986.html dev ML]
Helmut Kudrnovsky wrote
> hi,
> by testing the manual example of v.rast.stats, I get following error:
> v.rast.stats --verbose map=myzipcodes_wake at gbiftest
> raster=elevation at PERMANENT column_prefix=elev
> method=minimum,maximum,average,stddev,percentile
> Adding columns '['elev_minimum DOUBLE PRECISION', 'elev_maximum DOUBLE
> PRECISION', 'elev_average DOUBLE PRECISION', 'elev_stddev DOUBLE
> PRECISION', 'elev_percentile_90 DOUBLE PRECISION']'
> Adding column
> <elev_minimum>
> to the table
> Adding column
> <elev_maximum>
> to the table
> Adding column
> <elev_average>
> to the table
> Adding column
> <elev_stddev>
> to the table
> Adding column
> <elev_percentile_90>
> to the table
> Processing data (13 categories)...
> ERROR: Input window changed while maps are open for read. Map name
> <myzipcodes_wake_8088.0>
> Updating the database ...
> Statistics calculated from raster map <elevation at PERMANENT> and
> uploaded to attribute table of vector map
> <myzipcodes_wake>
> DEBUG=3 output
> <http://osgeo-org.1560.x6.nabble.com/file/n5232313/grass_cmd_output.txt>
> tested with
> System Info
> GRASS version: 7.1.svn
> GRASS SVN revision: 66569
> Build date: 2015-10-22
> Build platform: i686-pc-mingw32
> GDAL: 1.11.3
> PROJ.4: 4.8.0
> GEOS: 3.5.0
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Resolution: | Keywords: v.rast.stats, input window
CPU: x86-32 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:2 neteler]:
> Replying to [ticket:2778 hellik]:
> FWIW: there were two older (unrelated?) ticket with the same error: #1718 and #1775
Comment (by annakrat):
Very likely it was broken in r66551 (r.univar: Added raster region flag
"-r" to use the native region and resolution of a raster map, independent
from the current region settings), tested on wingrass binary r66548 where
it worked.
