GDAL
October 24, 2015, 9:49pm
1
#2779: v.external compile error --without-gdal --with-postgres
Reporter: Papillon81 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Vector | Version: 7.0.1
Keywords: | CPU: x86-64
Platform: Linux |
The module v.external gives a compile error when compiling GRASS 7.0.1
--without-gdal --with-postgres.
The following error shows up:
main.c:27:21: fatal error: ogr_api.h: No such file or directory
It seems like the ogr_api.h header should be conditionally included in the
main.c file or the v.external module should not be compiled at all when
gdal is disabled.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
October 24, 2015, 10:02pm
2
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by neteler):
The GDAL library is a requirement (see
https://grass.osgeo.org/grass70/source/REQUIREMENTS.html )
Why would you want to compile GRASS GIS without GDAL?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:1> ;
GDAL
October 24, 2015, 10:04pm
3
Comment (by Papillon81):
I saw that, yes. Why does GRASS offer a compile-time switch then?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:2> ;
GDAL
October 24, 2015, 10:10pm
4
Reporter: Papillon81 | Owner: martinl
Type: defect | Status: assigned
Changes (by martinl):
* status: new => assigned
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:3> ;
GDAL
October 24, 2015, 10:12pm
5
I think in is unavoidable for being able to set a path:
--with-gdal[=path/gdal-config]
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:4> ;
GDAL
October 24, 2015, 10:23pm
6
Component: Compiling | Version: 7.0.1
* component: Vector => Compiling
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:5> ;
GDAL
October 24, 2015, 10:29pm
7
Comment (by martinl):
I am unable to reproduce this error in relbr70 with `--without-gdal
--with-postgres`. It's compiled fine. BTW, I fixed some related issues in
r66591.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:6> ;
GDAL
October 25, 2015, 8:06am
8
Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: assigned => closed
* resolution: => fixed
Comment:
Should be fixed in r66597, backported to relbr70 as r66598. Closing, feel
free to re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2779#comment:7> ;
