[GRASS-dev] [GRASS GIS] #2783: mswindows / osgeo4w / grass.tmpl: OSGEO4W_ROOT_MSYS="@OSGEO4W_ROOT_MSYS@" not updated
not updated
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
FWIW taken from the ML dev
https://lists.osgeo.org/pipermail/grass-dev/2015-October/077033.html
>Then, I tested calling grass from MSYS shell, with the intention of
getting
some of linux shell funcionalities, >but the command grass70 does not
work... Attached, is a screenshot of the error i get...
the issue seems to be here:
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/grass.tmpl#L9
if I change this line in
C:\OSGeo4W_use\bin\grass71svn
to
OSGEO4W_ROOT_MSYS="$OSGEO4W_ROOT"
at least it: Starting GRASS GIS...
it seems @OSGEO4W_ROOT_MSYS@ is not replaced during packaging.
$OSGEO4W_ROOT is already set in an OSGeo4W environment.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783&gt;
not updated
  Priority: normal | Milestone: 7.0.2
Component: Default | Version: svn-releasebranch70
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows 7
Changes (by hellik):
* platform: Unspecified => MSWindows 7
* version: unspecified => svn-releasebranch70
* milestone: => 7.0.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783#comment:1&gt;
not updated
  Priority: normal | Milestone: 7.0.3
Comment (by neteler):
After the recent heavy updates still an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783#comment:3&gt;
not updated
Comment (by hellik):
Replying to [comment:3 neteler]:
the ticket can be closed as msys is now droped AFAIK.
it never worked because of this variable mix; it's obsolete now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783#comment:4&gt;
not updated
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
* status: new => closed
* resolution: => wontfix
Ticket URL: <https://trac.osgeo.org/grass/ticket/2783#comment:5&gt;
